hey question for the guys with widebands installed. Where did you mount your sensors? I got the LM-1, can it be installed into the stock 02 sensor hole? or does it need to be further down stream just dont want to wreck the sensor from excessive heat.
https://www.sau.com.au/forums/topic/219063-wideband-sensor-location/
  • Replies 63
do you mean 10cm up from the bend at the bottom of the dump pipe where it goes off to the cat? is it hard to get in and out? I'm not going to leave it in permanently. Did you have to mount it upside down to fit there?
ah awesome thanks for the picture. Where do you run your cable when the sensor is plugged in? just up into the engine bay then under the back of the bonnet and through the window?
Edited by SevenAngryPenguins
be sure to pay attention to the wideband sensors installation and operation instructions
i mean, actually read them, pay note to the location, mounting position and direction of the 02 sensor in the exhaust
incorrect mounting and angle can really trash the expensive sensor, i think they also need direct 12v ign power as they must heat up before running exhaust gas
yeah instructions were a bit vague I thought. All they said is that it can't be mounted upside down because of condensation, or before the turbo because of heat not much else really. But I'm having a bit of a read though the innovative forum before I install.
The LM1 is the best of its kind, Any reason why a perm gauge with a wideband couldnt be fitted? Ive seen them on ebay and would prevent me thinking im killing my engine...
Would a narrow band be suitable?
I think innovative sell dash AFR gauges/displays as well to connect with their WB's
pretty sure a narrow band would be pretty useless as an idication to an AFR display as it can't tell you how rich or how lean
I believe those narrow band gauages you tune them to rich lean stock or whatever setting, but ive got no idea. Does the power fc have an input for readings from the lm1?
http://cgi.ebay.com/Innovate-Wideband-o2-S...1QQcmdZViewItem
Edited by DECIM8
yeah read something about using the lm-1 narrow band output (0-1V) to drive a gauge not 100% though. The lm1 has analog outputs for ecu's I believe it can interface with datalogit and the emanage ultimate for data logging not sure about any others. That link doesnt work..
I installed an LC 1 and gauge kit
cost me 340 landed into australia from usa
didnt really work that great
then it died
I sent it back for warranty repair and they have replaced it with a new unit
but i havent got around to reinstalling
I've a little experiance with WB's, so ill throw my 2 cents in.
Manual has the preferred location and orientation that the 5wire should be mounted. Generally, you want it as close to the turbo as possible, though somewhere that wont exceed ~7000C (i think, its been a while) It's all in the manual. Just before the cat is always a good idea, though it can be mounted in a finned heatsink if you really want it closer to the turbine (or if its in a rota)
Being easy to get to, is an important consideration, as installed with the engine running and NO heater 12v will coke the refrence cell up.
Theres a fellow on the Innovative forum whos noticed how electrically "noisy" the LC1 is. Be aware of this when running the cable (more important in a perm install i guess) Reading the forums, seems heat can kill the LC1 dead quick too. Just be sensable when mounting.
...they also need direct 12v ign power as they must heat up before running exhaust gas.
Yup, its generally a 5-30s warm up time, depending on sender's temp.
The LM1 is the best of its kind, Any reason why a perm gauge with a wideband couldn't be fitted? Ive seen them on ebay and would prevent me thinking im killing my engine...
Don't know about best. They've had their fair share of defective / playing up units. Be this due to the LC1 being thier most popular (most used) unit, or an inherent issue with its design, I don't know. I thought about a PLX unit, though opted for the LC1.
Innovative sell 4 or 5 gauges you can use. I "think" the crappy Autometer style single wire gauges respond in a linear fashion to input voltage, hence you could run the analogue output from the LC1 into one of these. (I think one of the Innovative's gauges would be a better option though; you get start / stop calibrate buttons.
As mentioned, theres a programble analogue output on both LC1 and LM1 that can be pumped into anything with a analogue > digital converter. Emanage, ANY aftermarket ECU, datalogit etc etc.
Edited by GeeTR
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
