mine is a plx system which i beleive to be the best deal around. $275 off ebay direct from the US. and if you get their gauge well wow is all i can say!
my sensor is sitting perfectly flat in the front pipe just before the cat. works a charm with datalogit!
PLX Devices
  • Replies 63
i dont even know why anyone would buy anything other then a WBO2 product from www.wbo2.com
I have had mine for 13 months, i think the cable is buggard cos i run it through the door and the guy is soo good with his customers he is looking at it and replacing it for free.
They can even have input for 4 EGT thormocouples. 2mb logging... its THE shit.... and they are in canberra.
Edited by Guilt-Toy
yeah the wb02 stuff looks ace, i really dislike the power connector on that unit on the previous page, looks like it would come out of the socket very easily
that would be fatal to the 02 sensor if it did come out
what the plx one?
my plx device is just sensational. so easy to hook up and no mucking around at all. plus when i get the OLED display gauge for it and the rest of the PLX sensor systems my car is gonna be just like an aeroplane!
Yeah its great. The customer service from Peter @ techedge is awesome, he is allways willing to help. He is going to help set mine up to use k-type thermocouples, i sent mine back yesterday and should get it back fully working again by the end of the week!
what the plx one?
Yeah looks like the power cable can disconnect easily which will reduce the life of the sensor very fast.
WB02 is the only way to go, especially if your in australia!!
this one here
http://www.plxdevices.com/products/dm100/smafrcombo/
you can see on the wb02 the power connector has a coupler, so it cant come undone
if the unit looses power while running, youll risk the 02 sensor as the heater circuit needs to be live
regarding installation places, make sure you have it the way the manual says
on my lc1 they are anal about not letting moisture pool on the sensor, so mine is mounted upright in the "12 oclock position"
i was told that the WB02 products had unnecessary lag and that's why i chose to go innovate. however i really shouldn't have got the LC1 now that i know everyones experience's with them...
I had a fist full of cash for Pete 5 years ago, though heard from a few very reputable tuners about their issues with rapid elevation changes messing with the output. I saw a calibrated techedge unit compared to a motec (the older design)
Left a dirty feeling in my mouth, and didn't want to risk my motor (or others) with a device from a mom and pop operation.
I know the US Rx7Club uses (used) em like hot cakes... but Innovative, PLX make sell a LOT more :D
Once bitten twice shy I guess.
Just my personal opinion from the device half a decade ago, i believe these comments fit within forum guidelines.
Intercool, have you had a LC failure?
no mine is still going (less than 5000km's old)
but every 2nd person out there say there's was working one day and just stops the next. i don't even know if i got warrantee on mine.
i did have an immense amount of problem trying to calibrate and update it, and this problem still exists. i just worked around it.
i don't know if i should have gone LM1, PLX, or WB02 now. but i definitely wouldnt chose the LC1
wbo2 all good never had any problems and yes good customer support . had mine for 2 years and always runs faultless.
How many hours as the sensor seen, how old is the sensor, have you checked it against a known good unit for accuracy and response time recently.
Edited by GeeTR
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
