mine is a plx system which i beleive to be the best deal around. $275 off ebay direct from the US. and if you get their gauge well wow is all i can say!
my sensor is sitting perfectly flat in the front pipe just before the cat. works a charm with datalogit!
PLX Devices
  • Replies 63
i dont even know why anyone would buy anything other then a WBO2 product from www.wbo2.com
I have had mine for 13 months, i think the cable is buggard cos i run it through the door and the guy is soo good with his customers he is looking at it and replacing it for free.
They can even have input for 4 EGT thormocouples. 2mb logging... its THE shit.... and they are in canberra.
Edited by Guilt-Toy
yeah the wb02 stuff looks ace, i really dislike the power connector on that unit on the previous page, looks like it would come out of the socket very easily
that would be fatal to the 02 sensor if it did come out
what the plx one?
my plx device is just sensational. so easy to hook up and no mucking around at all. plus when i get the OLED display gauge for it and the rest of the PLX sensor systems my car is gonna be just like an aeroplane!
Yeah its great. The customer service from Peter @ techedge is awesome, he is allways willing to help. He is going to help set mine up to use k-type thermocouples, i sent mine back yesterday and should get it back fully working again by the end of the week!
what the plx one?
Yeah looks like the power cable can disconnect easily which will reduce the life of the sensor very fast.
WB02 is the only way to go, especially if your in australia!!
this one here
http://www.plxdevices.com/products/dm100/smafrcombo/
you can see on the wb02 the power connector has a coupler, so it cant come undone
if the unit looses power while running, youll risk the 02 sensor as the heater circuit needs to be live
regarding installation places, make sure you have it the way the manual says
on my lc1 they are anal about not letting moisture pool on the sensor, so mine is mounted upright in the "12 oclock position"
i was told that the WB02 products had unnecessary lag and that's why i chose to go innovate. however i really shouldn't have got the LC1 now that i know everyones experience's with them...
I had a fist full of cash for Pete 5 years ago, though heard from a few very reputable tuners about their issues with rapid elevation changes messing with the output. I saw a calibrated techedge unit compared to a motec (the older design)
Left a dirty feeling in my mouth, and didn't want to risk my motor (or others) with a device from a mom and pop operation.
I know the US Rx7Club uses (used) em like hot cakes... but Innovative, PLX make sell a LOT more :D
Once bitten twice shy I guess.
Just my personal opinion from the device half a decade ago, i believe these comments fit within forum guidelines.
Intercool, have you had a LC failure?
no mine is still going (less than 5000km's old)
but every 2nd person out there say there's was working one day and just stops the next. i don't even know if i got warrantee on mine.
i did have an immense amount of problem trying to calibrate and update it, and this problem still exists. i just worked around it.
i don't know if i should have gone LM1, PLX, or WB02 now. but i definitely wouldnt chose the LC1
wbo2 all good never had any problems and yes good customer support . had mine for 2 years and always runs faultless.
How many hours as the sensor seen, how old is the sensor, have you checked it against a known good unit for accuracy and response time recently.
Edited by GeeTR
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
