  • Replies 51
Good find on the engine parts, but please please please dont skimp on the $$$$ for labour costs in rebuilding the engine.
Mine cost 7k and is still runnning well, all rebuild at a well recognised mechanic etc. have a look at my SLY 33 gtst for sale thread and that gives you an idea of what i got, that included a wolf ecu as well. Unfortunately friends have gone for cheaper alternatives and have not gone as well with their engines, head gasket went on one of em.
I would go with shops such as Hyperdrive/top racing, prob two of the more well known shops.
in answer to your question about your gear box, troll through some of the clutch threads in the WA section as there was a great transmission and clutch specialist in Osborne park, I saw him about 6 months ago, its just near the triumph mechanic and WA suspension there, anwyays great old bloke and a whole heap of knowledge on the skyline boxes due to the amount of lcutches he had installed for all of the SAU crew.
sweet so im gonna cut costs in the pars department
by sourcing the parts myself
i havent had many recommedations on who to use in the build
so does anyone have any definate objections to using any particular workshops
cheers
cheers 25gtt i had only one in mind
purely cos the other is just to for away
guys ive been seaching and look what i found
ACL Forged Pistons and Rings (CP Forged also available)
Eagle Forged Rods (Optional)
ACL Race Series Mains Bearings
ACL Multi-Layer Steel Headgasket (Cometic also available)
Dupro VRS Kit (Engine Gasket Set)
for 2945 plus delivery
are the acl items up to scratch
or should i go the cp pistons and rings
i also found cank and main bearing kits for 86 and 128
cheers
i was allowing 200 for each
will variey greatly depending where u get it from
over budget is better then under :)
my bad!
Fair enough, I did get them trade but they also had to order them from Japan.
i read somewhere that the n1 oil pump is dodgey on street driven cars
something bout it cant pump enough oil at low rpm or something
not sure how true it is
I'm running an N1 pump and it flows fine and has heaps of pressure. I've only heard of N1's not being fine when they regularly see 8000rpm with lots of limiter bashing.
N1 water pump on the other hand, shithouse for daily driving.
