sleepy33 Posted May 15, 2008 Author Share Posted May 15, 2008 skyryan ATWELL represent i went to primary school with your bro yeah i dont think it will be long till it blows its surging at idle but only in drive and neutral(its auto) no idea what it is i have reset the ecu to no effect runs perfectly above idle on and off boost so with the oversized pistons should i wait to get the rebuild kit after the motor has been machined so i can see what sizes i need or would most machining places bore the block out to a requested size even if its not needed? cheers Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3869211 Share on other sites More sharing options...
R32 Driver Posted May 15, 2008 Share Posted May 15, 2008 you may want to look at strengthenin the auto box or a shift kit you building it yourself? or is a workshop/machine shop assembling it? id imagine they can just do it without the actual pistons and just the sizes build a rb25/30 torqe ftw! spoolimports.com has a fair few piston/rod packages and Sydneykid has used them pumping 500rwhp+ and still running Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3869434 Share on other sites More sharing options...
sleepy33 Posted May 15, 2008 Author Share Posted May 15, 2008 i am very much leaning towards a 25/30 ill get it done at a shop any recommendations a workshop i found has a kit for a 25 $5120 for parts plus labour which that said 1500-1800 depending on the condition of the head sound ok??? was thinking of manual convertion or shift kit and oil cooler and some strengthening havent really researched gearboxs in depth yet Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3869539 Share on other sites More sharing options...
R32 Driver Posted May 15, 2008 Share Posted May 15, 2008 breakdown of the parts? and there individual cost? labour sounds right, does it include cams? and i dont think the rb25 pistons would fit a rb25/30 and im sure spools rods r cheapest forged items you will find $645 a set be fare to say once u get a new turbo, manifold, engine rebuild, ecu and tune you wont get much change out of 10k Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3869735 Share on other sites More sharing options...
sleepy33 Posted May 15, 2008 Author Share Posted May 15, 2008 nah no cams no individual prices STAGE 1 $3205 cp pistons and rings eagle H beam conrods genuine nissan gasket kit tomei metal head gasket tomei assembly lubricant STAGE 2 same as 1 plus genuine nissan n1 water pump gates timing belt $3705 stage 3 plus ARP head studs ARP main studs ACL race main bearings ACL race conrod bearings $5120 Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3869807 Share on other sites More sharing options...
R32 Driver Posted May 15, 2008 Share Posted May 15, 2008 are those prices with or without labour? Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3869880 Share on other sites More sharing options...
sleepy33 Posted May 15, 2008 Author Share Posted May 15, 2008 with out labour 1500-1800 depending on the condition of the head would that be to put it in aswell Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3870221 Share on other sites More sharing options...
Chi100188 Posted May 15, 2008 Share Posted May 15, 2008 hmmmm you might as buy one of those rebuild kits off RACESPEC hes a sponsor for the forums and he sells kits for the RB25 which includes CP Pistons, Rings and Rods for 1850 so that saves you a bit on parts and also the main studs and head studs you can get off RACESPEC or high octane racing their website is http://www.hioctaneracing.com.au/eshop/ so i hope that helps anyways but yeah it'd be cheaper if you buy the parts yourself Cheers Chi Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3870247 Share on other sites More sharing options...
sleepy33 Posted May 15, 2008 Author Share Posted May 15, 2008 on the cheap ftw!! if there is a cheap way to rebuild an engine definately gonna try to cut costs anywhere possible but not cut quality does anyone recommend somewhere or someone to build an engine cheers matt Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3870273 Share on other sites More sharing options...
R32 Driver Posted May 15, 2008 Share Posted May 15, 2008 yeh fair few machine shops would be able to machine/build it but u still need a workshop to wack on the turbo (if u cant do it urself) ummm u can source it WAAAAAY cheaper if thats w.o labour check our CRD's package in the sponsor section they have a nice deal goin on Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3870300 Share on other sites More sharing options...
sleepy33 Posted May 15, 2008 Author Share Posted May 15, 2008 is it just me or is there no rb25 package from crd Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3870321 Share on other sites More sharing options...
R32 Driver Posted May 15, 2008 Share Posted May 15, 2008 email them about it it cant be far off the rb26 kit Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3870331 Share on other sites More sharing options...
Chi100188 Posted May 15, 2008 Share Posted May 15, 2008 man the CP package from RACESPEC is quality its cheap hehehe if u want quality and a price tag bust out some HKS, Tomei, Jun items pretty sure they'll make ur wallet lighter but if ur after good cheap quality parts then yeah Hi Octane or RACESPEC is the go Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3870554 Share on other sites More sharing options...
R32 Driver Posted May 16, 2008 Share Posted May 16, 2008 Hi octane is over priced, 3.6k not including gst, thats closing in on 4k for pistons, rings, rod, gasket kit, metal head gasket RACESPEC is very similar to SpoolImports (10 bucks more for the 25 package) RB25/26 - $1850.00 RB25/30 or RB26/30 - $2050.00 RB30 - $2050.00 SpoolImports 1. Package deal on 1 set of Spool RB30 H beam conrods with 1 set of Forged CP Pistons and rings. - $1990 2. Package deal on 1 set of Spool RB26/25 H beam conrods with 1 set of Forged CP Pistons and rings. - $1840 Both run CP pistons/some forged rods with ARP bolts CRD ARIAS Pistons EAGLE connecting rods NISSAN (Genuine) gasket kit TRUST drag metal head gasket TRUST camshafts ACL race series engine bearings Total price only $3599.00 Same price as Hi-Octane but u get cams and bearings (combined value around 800 more) Dont forget all these "rebuild" kits you need to factor in some of the following items if its not included Gates timing belt $300 crank/main bearings 400-500 gasket kit $500~ Optional Water pump $200 N1 or higher Oil Pump if your makin decent power $500+ ARP main/head stud kits 600-700 cant just throw in "forge pistons and rods" then go horray! 600hp ftw! Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3871555 Share on other sites More sharing options...
Chi100188 Posted May 16, 2008 Share Posted May 16, 2008 hahah u could for around 2 secs i guess ur right just shop around i mean if your doing a build don't skimp out on things hahaha but yeah Rebuild +GT35r = FTW hahah Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3871801 Share on other sites More sharing options...
bubba Posted May 16, 2008 Share Posted May 16, 2008 $400-500 for crank/main bearings? wtf? even ACL's aren't that much.. I'm running NDC's (jap brand) with no dramas and they only cost about $90/set for mains and bigends.. Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3871858 Share on other sites More sharing options...
R32 Driver Posted May 16, 2008 Share Posted May 16, 2008 ^^ i was allowing 200 for each will variey greatly depending where u get it from over budget is better then under my bad! Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3871869 Share on other sites More sharing options...
sleepy33 Posted May 16, 2008 Author Share Posted May 16, 2008 definatly gonna shop around heaps the racespec ones seem okay i read somewhere that the n1 oil pump is dodgey on street driven cars something bout it cant pump enough oil at low rpm or something not sure how true it is how long would a rebuild take at a shop taking into consideration other jobs and all that cheers Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3872082 Share on other sites More sharing options...
R32 Driver Posted May 16, 2008 Share Posted May 16, 2008 gonna have to call around dude and have a lengthy discussion about what parts are used etc Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3872401 Share on other sites More sharing options...
sleepy33 Posted May 17, 2008 Author Share Posted May 17, 2008 yeah gonna have a ring around im thinking the racespec kit arp main and head studs water pump oil pump crank and main bearings bout 3.5k plus labour oh and gaskets Link to comment https://www.sau.com.au/forums/topic/219066-built-rb25/page/2/#findComment-3873384 Share on other sites More sharing options...
