Im getting a little confused with some terminology being used.
Can some one correct me here.
Wastegates - All turbos have them. Come in internal and exteral formats. External vent to outside, Internal feeds back into the intake or exhaust?
Blow off Valve - Vents excess pressure when you back off the accelerator like between gears.
Bleed Valve - Same as a Blowoff valve?
Where does a Blow off valve vent? Exhaust, Intake or just to outside?
https://www.sau.com.au/forums/topic/21907-terminology-confusion/
You got the wastegates and Blow-off valve right.
Some blow-off valves will vent to atmosphere, others will recirculate back into the intake.
Bleed valve will increase the boost made, by bleeding the air to the wastegate line, hence making the wastegate open at a higher boost pressure.
Wastegate - Controls howmuch exhaust gas goes through the turbo, and howmuch goes straight out, to control boost delivered by the turbo.
BOV - yep, back into the intake on stock 'lines and into the air for woosh sounds.
Bleed valve- No, it is a cheap addition that bleeds of some pressure on the line to the wastegate so it doesn't open so much, so more exhuast goes thru the turbo and you get more boost. Electronic Boost Control (EBC) is a more expensive way of controlling the wastegate and hence boost.
not entirely correct about the wastegates.
the internal wastegate just means that the waste gate is incorporated into the exhaust side of the turbo from the factory.
external wastegate is an aftermarket accessory used for more accurate boost control and can be fed back into the exhaust or to atmosphere.
Not all, but most. :D Vent to exhaust otherwise you'd have exhaust going into your intake.
Yep, keeps the turbine spinning and reduces shockwaves travelling back to compressor.
The source of the force that opens the wastegate in our cars is compressed air ("boost" air between compressor and engine). The more pressure in this line, the more/quicker the wastegate opens, therefore if you reduce this pressure the wastegate doesn't open as much/as quick/as early. Bleed valve is an easy way to do this.
Never to exahust afaik, but to either of the others depending on the set up. Stock is back to intake.
although i'm sure some may have gotten those explanations i thought they were rather sketchy so i thought i would add:
blow off valve...
primarily used to prevent 'compressor surge', which is when the throttle body closes and the boosted air flows back through the intercooler and through the turbo which is spinning in the opposite direction. not good.
the bov opens up when the throttle body closes to direct boosted air out of the intake system. on a stock skyline it passes through a pipe and back into the intake so you don't waste the boosted air (and to cut down on noise)
wastegate...
when exhaust gasses exit the cylinders they flow towards the turbo. here they have 2 choices:
1) pass over the exhaust housing of the turbo, thus spooling up the turbo and compressig air in the intake. this is desirable if you are accelerating...
2) pass through the wastegate which is usually located right next to the turbo. remember back to physics and the exhaust gasses flow through the path of least resistance, thus pass through the wastegate and into the exhaust, thus bypassing the turbo and stopping/limiting the spool-up. This occurs when the turbo is at the desirable boost level. on some high-power cars this is not big enough to direct all the gasses around the turbo exhaust wheel, so they fit an externally-venting wastegate which generally flows more air. These are loud and pointless on a stock car.
bleed valve...
the wastegate needs to know when to open or close according to whether or not the turbo is boosting. a pipe runs from the turbo to the wastegate to tell it how much pressure the intake is being boosted to. the wastegate then opens or stays closed as required to keep the boost level even.
a bleed valve is a small (and cheap) valve that fits into this pipe and can 'bleed' (remove) some of this air. thus tricking the wastegate into thinking there is less boost than there actually is and make it stay closed for longer.
For those that know more than me (most of you), please correct any of this if its wrong.
Thought this may help bill.
Waz.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
