I have luckily come accross some money and was wonderin what mods i should spend it on.
Car - R33 Gts-t...."pretty rare these days"
Mods Already - GReddy Air Filter, Heavy Duty Clutch....*sigh*..i know dont laugh!
What i was thinkin..
1. JJr Turbo back exhaust w/ split dump $899.00 from Just Jap
2. Stealth FMIC $550.00 from Just Jap
3. Boost it to 10 Psi w/ Turbotech boost controller $30 from E-bay
4. Lowered with King Springs and shocks 35mm $650 from local suspension shop
5. CAI $190 from JS auto imports
6. Tune & Labour $leftover!! :P
Total - $2319
Also if I can save up for this week instaed of going out Front and Rear Strut braces.
Over all I want a nice lil package utilising both power and handling!
Would like to hear your thoughts.
Any other mods, seen cheaper, etc etc...all appreciated!
Cheers
https://www.sau.com.au/forums/topic/219075-yay3000all-mine/
:P ..eeek...
how much?..what bout a re-map?
or Apexi Safc???
how much u asking for NYTSKY?
ask yourself how much power do you want in the end? or wat you want your car to do
and do your mods according to that
PFCs go for around 1500 these days...
if your going the power root, i highly recommend a FMIC + the turbo back exhaust MINIMUM
Edited by R34NRG
https://www.sau.com.au/forums/topic/219075-yay3000all-mine/#findComment-3863722
Pretty much what ive set above is all i want to do.
Wanna Start saving for a house...so would a Power FC be REALLY that beneficial!
Is it possible to tune with the standard computer?
What about regapping my spark plugs from 1.1mm to .08mm to overcome the flatspot?
https://www.sau.com.au/forums/topic/219075-yay3000all-mine/#findComment-3863747
plug and play??
by this u mean it has tuned settings with the respective mods i have, or will i have to re-tune it!
It will need to be retuned mate,even if i had the same mods as you it would still be smart to have it retuned.
But it does have a base map in it that will get you around until you get it tuned.
https://www.sau.com.au/forums/topic/219075-yay3000all-mine/#findComment-3863881
Front and rear swaybars - $550
turbo back exhaust - $500
PowerFC - NYTSKY is selling one for $1250
Turbotech boost controller - $30
FMIC - $500
Save the rest + a bit extra for a tune.
At about 12psi you should come close to 200 rwkw
Fit the parts yourself and learn something about your car
Don't just buy lowered springs, you will flog out your stock struts in no time and the ride will be shit anyway. The swaybars will make a huge difference to handling and you will retain some ride quality.
My 2c
https://www.sau.com.au/forums/topic/219075-yay3000all-mine/#findComment-3863950
If what you have listed is as far as you are going to take your car, I suggest the following;
Swaybars, pineapples, adjustable bushes (camber & caster), & hicas lock bar $1k
Brake pads and braided lines $400
R34 Gtt side mount intercooler $150
Turboback exhaust (I would go for a custom or second hand jap) $1k
Toshi ECU remap $400
All up $2980
Bang for bucks in terms of handling, braking and grunt.
https://www.sau.com.au/forums/topic/219075-yay3000all-mine/#findComment-3866585
All up $2980
Toshi ECU remap?
never heard of that...any more info on that please..thanks in advance..
Like to also say thanks to everybody that has contributed ideas for this.
https://www.sau.com.au/forums/topic/219075-yay3000all-mine/#findComment-3866917
gt3076r - 1620
powerfc - 1250
gtr fmic - 250
get dump to suit your exhaust: 300
drop a skid...
abliet over budjet haha
on stock injectors and fuel pump... riiiiiight...
what tuitahi said is right on the money...
esp the camber and pineapples
but i wouldn't bother with the braided lines and would use the $400 for fmic
https://www.sau.com.au/forums/topic/219075-yay3000all-mine/#findComment-3867702
if ure getting an fmic.... save money on the CAI and make it yourself. it will cost u 20 bux if u buy some PVC pipes from bunnings (u can put it through the standard cooler holes) im sure it wont b as good as actually buying one..but it will be very close and with the money saved u can buy a strut bar or some petrol... also if those are all the mods that ure going to do..u might want to look into getting a jaycar digital fuel adjuster. works like the SAFC but it will only cost u like 200$ with the tune (look it up)
https://www.sau.com.au/forums/topic/219075-yay3000all-mine/#findComment-3867804
cooler 550
exhaust 500 (second hand)
pfc (1250)
gtr injectors (200-300)
boost (free)
u dont really need cai just get a pod (second hand ones are always around in the for sale section) and like above make a cai for real cheap these days
then u have enough for a good tune and some petty
https://www.sau.com.au/forums/topic/219075-yay3000all-mine/#findComment-3869576
JJR Stainless Dump/Front Pipe - $250
XForce Stainless Hi-Flow Cat - $180
Fuel Pump - $160
SAFC Neo - $400
Trust FMIC - $620
Apexi Pod - $80
Total: $1690
or instead of SAFC Neo you could get a Power FC
Power FC - $1250
Total: $2540
If I had the cash this is what i would buy! :spank:
https://www.sau.com.au/forums/topic/219075-yay3000all-mine/#findComment-3870081
JJR Full Exhaust (includes dump/front, stainless cat and cat back) $899
PFC $ 1250
Trust Intercooler Kit $664
Turbotech Boost Controller $30
PFC Tune ~$400
Total $3243 (Just a little bit over)
OR you could cancel out the power fc and get yourself some nice shocks, spring and swaybars.
BUT if i were you and you were never going to go any further with engine mods I wouldnt worry too much about a pfc because i dont think the power gains
will be huge. You will probably gain about 20kw and a better power curve but i dont think it will be a huge difference in noticeable power. You will get much more
enjoyment out of a few good suspension mods.
https://www.sau.com.au/forums/topic/219075-yay3000all-mine/#findComment-3870133
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
