Exhaust - 500-900 (2nd hand vs new)
Turbotech @ 12 Psi ($40?)
R34 SMIC - $150
Toshi ECU remap (search for it) around $400
You will the have 200rwkw - very good power and response for $1200
Whiteline Swaybars from Garage 13 - $380
2nd hand Adjustable Coilovers - $500-$800
Now the car handles well for under a grand if you look for a good deal
QFM K500 brake pads - $150
QFM Stainless Steel brake lines -$250? (not exactly sure on price)
Good brake fluid - $70
Now the things stops! for under $500
Spend the rest on labour or beers to help you DIY!!
Hehehehe, looks remarkably similar to my suggestion.
R34 SMIC - $150
If you get a pod get a 3a racing they are the best and only like $40 bucks, you will need adaptor too which is about 30
Do you have proof to back that up??? What makes you say they are the best?
It is generally acknowledged that you should either get a K&N Panel filter or if you are getting a pod, get the Apexi Power Intake which you can get for $89 delivered (no need for adaptor....)
http://www.skylinesaustralia.com/forums/Ap...op-t155204.html (Apexi Power Intake)
Heres the results of a filter test:
http://mkiv.com/techarticles/filters_test/2/
Edited by Az_StrYdeR
Has been covered many times before, off topic but since you asked auto salon magazine issue 51 2007
Look at 3aracing.com and look in the air filters section it has all the results.
JJr Turbo back exhaust w/ split dump $899.00 from Just Jap
Stealth FMIC $550.00 from Just Jap
Boost it to 12 Psi w/ Turbotech boost controller $30
If you still have an airbox i would stick with that and just get a panel filter, especially if your in vic.
Add some sort of piggy back or retune and you should be happy.
but in the end it depends on how much power you want.
Ummmm..gee guys.
With so many suggestions it is so hard to actually figure out what i exactly want now.
This is what im def gettin so far...
- JJR Turbo back exhaust
- Stealth fmic
- Toshi Retune @ 10-12 psi w/Turbotech boost controller or if i can save up i'll get a GReddy Profec B
As for handling...still dunno!
Was thinkin about 2nd hand coilovers, and sway bars.
Would like suggestions for Suspension and handing...roughly bout $1400 to $1800 if I don't go out for the next 2 weeks.
i would not bother for now, i believe the suspension in my car is standard and for a daily driver it handles pretty dam good as it is, personally i would leave the handling, get the mods you mentioned done and go out for the next few weeks, in a month or so after the mods are done then decide if you want cooil overs or not, this will also give you more time to see what is out there and get better opionons on what people think of brands and coil overs in general, i have noticed a few ppl selling there coil overs lately and going back to standard because it is too stiff for a daily driver.
dont quote me on this, but apparently swaybars (under 400$) give significantly increased handling without comprimising the ride quality (again dont quote me on this). so u should look into this. also if u think ure a bit handy, getting a pod and making your own CAI is worth-while. and if u dont want to keep peeling the defect stickers from your windshield, id also make a heat shield for it (plenty of guides on here on how to do it, just do a search).
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
