can someone who's done this give me a step by step guide on how to take out the standard radio/headunit completely?
i've tried but the thing doesnt even move!
anyone?
1 - First pull out the ashtray and undo the screw behind it.
2 - Pull up the gear stick surround and undo the 2 silver screws at the bottom left/right of the storage bin.
3 - Using a thin flat blade screwdriver on the left side, prise out the 2 vents at the top of the console and disconnect the unit.
4 - Undo the 2 silver screw at the top of the heater controls.
5 - Pull out the heater controls, radio & stage bin (all in a cage together).
6 - Remove the radio from the cage (2 screws each side) and fit your radio.
7 - Using the following parts PC2-76-4 and PC5-87 connect your radio to the cars plugs.
8 - Refit going from step 5
pretty simple, ive done it a few times :P
^^ as above, but just be extra careful when you're taking out the air vents with the flat blade screwdriver, the paint is very easy to scratch.
Take your time and it will be sweet
Edited by R34GTFOUR
  • 3 years later...
how do i do this step which screws ? post image if possibl please?
You do exactly that. Pull up the gear stick surround (obviously unscrew the gear knob) just pull the surround up and out. the screws will be quite easy to see once its up. Also don't forget that the cigarette lighter socket has 2 small plugs connected to it, so don't pull the surround out too far.
Have a tea towel on hand or similar to rest over the gear area. It allows you to remove the setup straight backwards without touching the sides, then rest the unit carefully while you remove plugs/leads from the A/C and stuff. As mentioned the plastic either side of the unit will scratch it you look at it sideways.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
    • Nice. I'm looking forward to the updates!
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
