Gday guys & girls
Unique Autosports is putting together a new mailing list for customers and other interested parties.
Joining the mailing list will ensure that you are informed of all upcoming UAS events such as their trackdays, and special offers.
If you want to be kept up to date on the latest news from UAS please send an email with "JOIN" as the subject.
Please include at least your first name, State, Type of vehicle (optional) and your preferred email address through which to receive the news letters.
To join simply email: mailgroup@uniqueautosports.com
https://www.sau.com.au/forums/topic/21910-uas-mailing-list/
  • 5 weeks later...
  • 3 weeks later...
  • 1 month later...
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
