  • Replies 95
Posted Images
I'll have some photos by the end of the week. I have close to 5,000 to go through. I should be able to get a few done tonight that i'll post up.
haha 5000..you like punishing yourself when it comes time to go through them, dont you?
nice one guys. instead of sabotaging snowys car i thought some rain might do the trick...
Great work Team Cheaterer GTRs. Considering the elements it was an out of this world effort to be where you are in the results. If it was dry or semi dry for some more events i think you would have been in a higher position.
And top work to Pete, easily the most excitable Dutton entrant of 2008 :)
Hey guys
WHAT A WEEKEND!
Man, Dutton is a great event, lots of fun, lots of car talk and even more smack talk.
I ended up taking out 1st Rookie Co-Driver which is pretty cool. To the best of my knowledge I'm the ONLY SAU person to have one of them....... mind you it's only been around for a couple of years, so that's probably why.
Jeff and I were in 8th position outright on the first day, and I think we dropped off a little to about 11th on the second, mainly because it was pissing down and we seem to have gotten some really shocking conditions on some of our runs.
Day three we went to Sandown and I popped my cherry there in the pissing rain. Nothing like coming up the back straight at 200 kph in teh wet, with barely any knowledge of the circuit, but the GTR stuck firm and simply needed a gentle brake foot!!!
Jeff and I ran almost identical times on many of the events which shows that we were driving the GTR to it's limits, so maybe next year we will use a better mouse trap :)
Jeff did however beat me more times than I beat him, so I guess that means he's still faster than me..... I guess. >_<
All in all, I had a ripper weekend, and I added many more car sounds to my already impressive collection.
Yes, there was drift, yes there was blazing power slides and yes, I enjoyed every second of it.
Yes, there was also a breakage in teh GTR, the good old front diff had a fit and smashed itself. It had been picking up the wheels and spinning them all day in the wet and we think it just wore out eventually on a launch at Bombardier carpark.
Luckily I had enough of a points lead to end up winning my Rookie by 70 points which is a fairbit I suppose.
Thanks to Jeff for letting me loose in what is a pretty complete and fast car, all it needs to be even quicker is a handbrake that works and a tail that's a little more happy. But it's a Targa car after all.
The purple one however, is not :D
BASS OUT
Jarrod.... Where are those photos of me in Jeff's car !!!!
Hey guys
WHAT A WEEKEND!
BASS OUT
Pete did a great job for his first Duttons
Not sure he knew how competitive this event is
how ever the 63 year old granddad still won 21 events to Pete's 13
Maybe next year
thanks Pete for a fun three day
and I promise to open the windows next time the odors build up too much
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
