  • Replies 172
Posted Images
Yeah I'd like to thank Archie for reminding me I'm still alive. There's nothing quite like going through the kink backwards at 150km/hr to point it out to ones self.
You're most welcome :D
You should of went home and hugged your family and told them how much they mean to you and returned that library book you borrowed in 1985.
I actually enjoyed myself and was spewing i didn't get a crack at a better time when the sun came out later on.
The first practice session of the day when the track was at its worst i tootled around and did a PB of 1.23.2.
On my previous (and first) outing there with good track conditions I managed a 1.23.5 and this was with a single turbo setup.
Just goes to show how much better the current twin set up is :D
I was glad though that there were no casualties due to my oil spill. I had no idea i was leaking oil as i drove around and exited the track.
Juz picked it up and mentioned it in the pits and we thought we better let clerk of course etc know asap but i imagine by that time a few would have already gone over it.
Jarrod that's no excuse! I wanted a pic damn it. If you're in the in-field than that means you're hardcore and can take a hit.....even if it is from a car!!
ROFL @ Adz
I almost cried seeing the lovely silver 32 with damage on it:(
?? :teehee: ??
Now I can finally have a race track time in my signiture!
Tim. You did well to hold this one! Over the ripple strip!
well despite the usaul issues i had an absolute ball. killed my pb by 4 seconds and the other datto boys also whipped out pb's. Good work russman, has the bug bitten now? haha
i seem to have issues with the nuts that hold my turbo on the manifold constantly coming loose. its a top mount and the nuts wind their way up! so i end up spending most of my day either driving or fixing and don't get to wach too many others.
i'm glad the pre 89 class is starting to get quicker too, look out skylines haha
yeah we got through scrutineers ok :teehee:
but it was short lived for me, fried my rear pads to the metal after the 2nd session and wasnt making much boost all day, (found out when i got home the wastegate actuator had un bolted its self,) but it makes me feel even happier with my 1:26.7 knowing i had no boost.
well done to leigh, posted good times and drove home. (no trailer)
and crossy back in the corona, lasting all day.
cant wait till nex time.
.... but it makes me feel even happier with my 1:26.7 knowing i had no boost.
Top work on the great time. Yeh, its great to see that with a wider cross section of cars and driverr everybody is still going scary quick. Back in 2004/2005 that would have been quick enough to get you into the top few cars inc all the GTRs.
No doubt with time, practice and development there is more fin to be had. LOL, i cant imagine punting a 1600 around a place like Sandown with the slow corners. SO much steering effort must be required!
Some data from the day - unfortunately for me, my fastest session (session 3) hasn't logged properly so no comparison base for next time - I'll be flying blind! :P
Best theoretical time with all fastest logged sectors was 1.20.6 - shows how inconsistent I was on the day with a fastest of 1.21.8, blah... :)
Looking at lat and long G ratings the track wasn't as bad as it felt as I have never recorded more than 1.5G's under brakes (1.41 G's last year, however my pads were nearly shagged on Sunday and should have changed them) although the corner loads were down at bit, would normally see 1.35 - 1.4 G
Interesting stuff Andrew. I notice your top speed was about 9km/hr down on my recorded top speed (235km/hr). But my top speed was about 10km/hr down on where it usually is which makes sense based upon where my shift points on the back straight were on Sunday.
But the thing I'm finding most interesting is you saying the braking forces were up from the past. I know I was having to brake into turn 1 at around the 200m mark where normally I brake from around the 170 mark so I was finding braking distances were heaps longer than usual (turn 2 was another I regularly struggled to pull up in time for all day long).
Sorry, probably gave the wrong impression. My braking force was down on last year, just have a look at the minimum longitudinal G's - they are 1.34 for Sunday and I was getting over 1.41 G last year. I had a scan back to some old data and I have never got 1.5G's under brakes on any track is what I should have said, at least in the data that I have saved.
I agree with turn 2, a few times I thought I was going into the ditch, I just turned right and hoped for the best.
With the shitty corner grip I was getting, I was getting lousy exit speeds, no doubt giving me a lower top speed. I was not pushing the car after the spin as I wanted to drive home. :thumbsup:
So what you are effectively saying is that compared to your last visit to Sandown your braking longitudinal G's are down and your cornering lateral G's are also down - but yet you managed to set a new PB for Sandown! That's a fair effort :thumbsup:
Guest
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
