So what you are effectively saying is that compared to your last visit to Sandown your braking longitudinal G's are down and your cornering lateral G's are also down - but yet you managed to set a new PB for Sandown! That's a fair effort :D
An extra 40kw does wonders - more straight line speed outweighed less corner speed and reduced braking performance.
  • Replies 172
Posted Images
How's that yellow snow Andrew? :blush: Trouble with linking to images on a server in someone else's control is... they can just replace the image :D
See attached for the practice session times for group 5 :thumbsup:
080601_Practice_5_Lap_Times.pdf
Not sure how many of you guys are running video cameras in /on car but I just found the perfect double suction cup mount for a pencil/webcam.
Bought one in ALDI called a "Bath or Shower Support Bar" for $9.99 !!
PERFECT! Double suction cup safety prob could hold a handy cam as well they seem so strong on a decent flat glass or metal surface.
Works great with a $80 Eight (8) Megapixel bullet webcam "SPEED S8850i PC Camera" at 800 x 600 32FPS USB connection into my Laptop.
Just put a circular hose clamp onto the bullet cam mount around the mid handle and adjusts to any angle.
Great VIDEO for less than $100 - NOT inc laptop of course! :yes:
And what do you need software wise on your taptop to record
Roy, the webcam comes with AMCAP & VP-EYE software and the video drivers for the bulletcam
but you can use the native movie maker in windows or any other video capture software.
Will put up some pics soon.
Guest
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
