Hi All,
unfortunately I am strongly considering selling my skyline, after 6 years of love and about 50k spent I have my heart solemly swept by 2 cars, one being of course 34GTR the other being an Honda NSX.
I am seeing some beautiful NSX's coming up on draganddrift.com in the circuit section, however, these were banished with the new SEVS scheme, if i recall correctly.
Now every so often personal imports can come through etc etc, also I have heard of some other ways of getting special cars in (some are starting low volume imports of the 35GTR if I am not mistaken)
What options do I have in getting an NSX to my door. think can do, not cant do :-) surely there must be a way?
Surely SOMEONE out there must know a way to get one in, low volume import?personal import?your assistance is needed.
Thanks in advance for your time.
  • 1 month later...
They were sold new in Australia for a time, so your chances are not good.
Check for anyone offering compliance (doubtfull)
Additionally the Japanese know the value of the late model versions and some of them go for huge money.
Why not just try & find one locally?
they cannot be imported or complied under any current scheme. the ONLY ways are personal import (completely impractical unless you live in japan) or race only import. if you want one for road use the only viable option is to buy one that is already here.
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
