hey guys how are ya
i am changing my rego from vic to qld as i have moved up here.
been driving around with vic plates for 3 months so far.
i drive white r33 from brisbane area. ippy way
so just wondering wat the go is.
i changed to qld license today and they said that i have only 14 days to change to victorian license. is that true??
only 14 days. i thawt they gave u a couple of months.
and now more importantly i am just wondering wat the go is with changing over
it has a question about modifications, i have intercoler and boost comtroler and exhaust etc etc.
it says if answer yes u may need to get a modification plate or something???
and it says something about inspections and stuff??
back in the day it used to just be RWC and there ya go..
so any one got any idea?? do u jsut need a RWC or wat??
help would be appreciated. thanks
https://www.sau.com.au/forums/topic/219213-changing-to-qld-rego-from-victoria/
I had a look, by the sounds of it (question 16 on the form) that is only for major mods that do require a mod plate. So unless you have anything which actually does need a mod plate just put no. You shouldnt be able to get a RWC if you have un-modplated mods anyway.
Yes CTP IS compulsary, thats what th C stands for. you pay that at QLD transport.Its different tyep of insurance to third party fire and theft etc from just cars.
Edited by R334door
changing rego is easy
you have to get the right form, its the same form as registering a new car but seeing as the rego is already in your name there is no fee to change over other than the cost of buying number plates
you need a RWC and you need to take this with your form and your car to a QLD transport office
then they will inspect your car to check that the engin and VIN numbers match with your form and you're done. you obviously have to pay QLD rego but you will get a refund of your remaining VIC rego
CTP is a compulsory insurance that is normally included in the VIC rego already. in QLD they allocate you a CTP automatically but you can choose a different one if you like.
this is separate from insurance which you still need to change over to your new plates with your insurance company
best of luck!
Warren (ex-victorian)
Edited by WazR32GTSt
But you can't transfer rego interstate so there would still be the normal rego fee.
best of luck!
warren you make me laugh... quote yourself :D
and yes warren has confirmed it.. however there is an admin fee of $21.05 for new car rego.. i dont think they waive that fee even if it's your car (i mean dont forget this is the government here..
cliff.. i'm sure you meant in your question they giving you 14days to change to qld plates? (not vic license?).. just follow what warren has given you.. get a qld rwc (as rules on mods, etc are diff in all states) fill in the new car rego form (they dont recognise vic rego.. go down and register the car... while your there hand in your vic number plates.. they give you a receipt for the plates.. then you go on the vicroads website and get a form to mail (with receipt) and they will send you refund on your remaining rego..
Just Car insurance is easy jus update the address and plates.. but ctp is insurance on injuries to related parties.. diff from just car who insure the vehicles.. you get a choice of ctp insurance in qld.. (as the other guys stated)
i think it's roughly $340.00 for six months rego (including ctp)
done.. although that pretty much what warrren has summed up :(
Just reregistered my 34 recently.... all CTP is very very similar price in QLD within about $10 max from memory.... I'm with Allianz with mine ( I work for them, so I know wat I get for it... no discount still) 6 months is $333.00 total, $144.00 for ctp, rest was rego and fee and fee blah blah blah... 12 months was $634.95, $272.00 ctp rest is government pocket's stuff..
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
