i was just having a debate with some friends as to whether a GTR(any yr model preferably the fastest model) would b able to take on a honda NSX(also any yr) stock for stock. some statistics would b greatly appreciated or a link. also am i right in saying the nsx's werent aus delievered as i hav only eva seen one on road.
https://www.sau.com.au/forums/topic/21922-gtr-vs-nsx/
  • Replies 43
2002 NSX- 0-100 5.9sec
Topspeed- 270km/h
2000 GTR 0-100 4.9 sec
Topspeed- 180km/h (limited)
But it would be pretty close around a race track such as the nurinberg ring (sp.)
The Skyline has heaps of room for modification while the NSX has nearly none (except for turbo charging, which is very expensie and difficult).
Greg.
https://www.sau.com.au/forums/topic/21922-gtr-vs-nsx/#findComment-466193
Originally posted by redline2003
omg even for a $120000+ car honda cant even make a 13 second car.
The NSX is sooooooo much more than a 1/4 mile timesheet... but point taken, it *should* be quicker point-to-point for the money.
https://www.sau.com.au/forums/topic/21922-gtr-vs-nsx/#findComment-466448
there's a video of a 34R and a NSX R spec or whatever the top spec is on the web drag racing.. the NSX gets a 13.0 or there abouts and the R got a 13.3. I think it was a best motoring video
the R kicked its ass on the launch but then the NSX started to catch and overtake it, something i wasn't expecting.
ill try find the video tonight if i remember.
Shaun
https://www.sau.com.au/forums/topic/21922-gtr-vs-nsx/#findComment-466645
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
