Moving out all these parts as I'm selling my car and have no use for them anymore . All parts are quality and new or near new grab yourself a bargain . All items don't include postage pickup also available in Sydney .
Item: Greddy Plenum
Age: New
Condition:New
Price: $950
Contact: Private message or email [email protected]
Comments: Greddy Plenum brand new never used comes with everything as delivered from Greddy . Manifold has been smoothed and professionally painted in bright silver 2pac looks stunning .
Item : Q45 throttle body
Condition: used
Price: $200 Pending sale
Comments: Used q45 throttle body pefect match up for greddy plenum can work out negotiate package deal with plenum
Item : Jim Berry Clutch full monty to suit r33 GTS-t and others
Condition : Brand new
Price: $1100
Comments : Orded from Jim few weeks ago this is exactly how I got the clutch kit from him . It's his signature full monty clutch to suit r33 GTS-t and also others .
Item: Tomei Pon cams to suit RB25det
Condition : New
Price : $650
Comments : Tomei pon cams 256deg to suit rb25det brand new in the box as recieved from slide performance
Item : Tomei Adjustable cam wheels
condition: New
Price: $280
Comments: Tomei Adjustable cam wheels to suit RB engines both wheels brand new in the box never used
Item : Splitfire coil packs to suit r33 series2
Condition: used
Price: $400
Comments : Splitfire coil packs in original box to suit r33 series 2 . They haven't been run in the car but were just placed in the engine for a couple of days they are pretty much unused .
Edited by 7heavn
Where did you get the plenum painted? And how much did it cost you? Do you have a paint code for it?
Im sending my pressure plate to jim tomorrow.Will get it back all nice and upgraded with a 5 puk carbonic and sprung clutch plate.
This is a good price for this clutch,whoever buys it will be extremely happy.
Are the Poncams for RB25s up to 9/97 builds?
I'm a spray painter by trade I did the plenum myself it's a show quality finish I spent alot of hours getting it right The colour is straight 513B debber base coat silver with debber MS 2pac clear . Pon cams where to suit my 96 ser2 GTS-t.
I assume you are in Sydney.How much would you charge to do the paint on my Greddy Plenum?
honestly just buy his then re-sell yours!
PS that plenum looks schmick!
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
