hey guys, thought id run it pass the general consensus - will i blow my turbs?
i have rb25det neo
mods i have:
big frontmount
big plenum
bigger fuel pump (forget what hp)
microtech ecu
3" exhaust (no cat or rez)
air filter
bleed tee
stock: internals - turbo - injectors - coilpack
had a dyno run @ APC brisbane - and made 243rwkw on vpower... but no idea what psi im running atm...
at stock 7-8psi was 200rwkw
when i picked up the car - the dude at the front desk did not know cuz the guy who tuned it wasnt there at the time.
he did however tell me that my boost was taken to the highest limit and reduced somewhat to keep it "safe"...
(i dont have a boost gauge and i will call them tomorrow..) But i was wondering if anyone else has a setup similar to mine; what boost level you guys think id be running... but most importantly; you guys think its safe at this power level for my turbo...
cheers for your input yall!
https://www.sau.com.au/forums/topic/219253-will-i-blow-my-turbo/
10-12psi = safe. Any more is reaching failure point.
243rwkw is a flat fudge too dude, should be around 200rwkw at the most really.
Not sure why you would put all that "big" stuff on there and run the stock turbo though, just adding in bad response to the setup for no reason at this point
242rwkw for a standard rb25 turbo is impossible. 242rwkw for a highflowed standard rb25 turbo is possible.
Standard injectors would max out before 242rwkw, so thats an immediate giveaway that the provided kw output is incorrect and that its just a standard turbo. Its 200rwkw on average for a standard turbo.
as stated 12psi max for standard rb25 turbo's. The ceramic exhaust wheel is prone to let go at anything higher.
yea, im pretty sure its not high flowed - plus i just gave it a proper strap and its not feeling near the pull my friend gets in his 254rwkw r32... so.. i guess ive been had.. damn you APC!! :D
thanks for the input guys! i guess ill question them about it tomorrow when i ask about the boost level...
I think the first thing you should do is get a boost gauge to see how much boost you are running...regardless of whatever amount of boost they say the car is running...
That said right...the way a car feels can be deceiving...the comment you made about your car feeling slower than your mates R32 is kinda similar to how i felt when i went from driving my 210rwkw R32 to a mates 240rwkw R34...the way the power is delivered all makes the difference...but i can confirm that his car was definitely making alot more power...its just that it came on so smoothly that it made it feel not as quick...
yea, cheers limpus - boost gauge is my next thing-to-get... and youre probably right about the ride.. maybe i need to drive it a bit more - to appreciate the tune..
ill post a scan of the dyno print out tomorrow..
tho i gotta say ive got a growing suspicion that they have taken me for the biggest ride ever..
to fix a leak from a grub screw on the oil sandwich plate..
pre-dyno inspection - spark plug clean - replaced fuel hose from pressure regulator and replaced efi hose clamps. Installed bleed tee, adjusted air fuel ratio. adjusted boost setting and timing maps. they charged about $950..
Ive only ever once had a tune in the past - it cost me $250-300.. not that i mind spending the money but its the principle - why would they fudge the results of the tune... i mean, what else did they lie about - or i could be getting ahead of myself i guess..
its not what you pay... its what you get.... if the car is running $950 better thanits all good.... (although you dont seem to think so :D )
they lie so that you come on here and tell us how much power they got from your turbo and then we all go there for our tunes because they are soooo good!... not really a well thought out plan as they'll more like lose custom
well.. they did also fix a spring in the BOV. the labour was $720 all up excluding the parts.. i just hope they did tune it and didnt just turn up the boost or something.. im just not a fan of being lied to - if they didnt hype up the dyno results i would have been cool with it..
lesson learned for next time i guess.. :D
lesson learned for next time i guess.. :(
i was sarcastic about the spring btw :D
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
