R34 Gtr Instrument Cluster Into Gtt?
Can you put a R34 GTR instrument cluster into a R34 GTT?
Inparticular a NISMO 300km/h GTR cluster into a GTT?
Will it just plug in?
I'm not to sure about the GTR cluster, however you can get the R34 GTT Nismo 300km/h for the GTT straight swap.
I have this NISMO 300km/h cluster in my GTT
no it wont because the GTR has AWD sensors and everything which the GTT dosnt, it would be stupid to put one in wen you can get a 300km one that will work 100% for the gtt.
http://www.nengun.com/nismo/combo-meter-skyline-r34-gtt
Edited by R34NRG
already aware of GTT NISMO cluster.
I like the look of the white faced GTR NISMO cluster better, hence my question is not stupid.
But thank you anyway R34NRG.
p.s. DOSKI your GTT is one of the better that i've seen, great job.
Edited by OON80
p.s. DOSKI your GTT is one the better that i've seen, great job.
if you want white faces just take them out and custom job it.....my apologies if ive made it sound like your an idiot. you didnt mention anything of white faces in your original thread so i assumed u wanted it for the 300kms read out.
peace.....
I was hoping it would be easier and not have to resort to custom work. I should have known by now nothing is easy. Any ideas on how to custom job it. I probably should search the forum first, never mind.
Thanx R34NRG
p.s. why has the GTR dash need of connection to AWD sensor? couldn't these extra connections just not be connected and have all the appropriate dials connected? (this is just me still hoping for an easy option.)
I've got both here, it's wired all arse about face on the back, needs extensive work to fit one into a GTT as the pin-outs for the plugs are vastly different.
Is there any laws or regs to consider when replacing the speedo? or is the speedo a separate part and the nismo meter just has a cut-out for it?
I've been wanting to get a nismo dash for some time, lights up very nicely too!
is the nismo meter directly plug to plug cvompatible with the GT-t?
  • 16 years later...
Where are u located? U got nothing on your sig
There’s a place in Carrington (Newcastle) that refurbishes speedometers/gauges.
They can also adjust the new odometer to the kms’ of the previous odometer and supply a certificate, also re calibrate the speedometer
In Sydney. I didn't want to update the cluster originally for that reason of, I had no idea where to find someone who does calibrate the km's, also it's expensive af lol. Just wanted to make my faceplate look a bit more modern.
Edited by silviaz
19 hours ago, GTSBoy said:
Sorry to sound thick....but what does the "faceplate" have to do with adjusting the odometer? Surely the odo stays put and you change the fascia. Surely they are not the same thing.
Not with adjusting the odometer but the calibration of the cluster, because the dials are in different positions I believe? a 180kph cluster vs a 320kph cluster.
Edited by silviaz
Hang on, You want to put a 320km/h faceplate on a 180km/h speedo? That's not how it's done. You get a 320 km/h speedo.
It's probably relatively simple for an instrumentation specialist to recal a properly electronic speedo like that, provided that there is a means provided to do so. For an older analogue/electronic speedo, the factory adjustment might be little more than a pot that allows a +/-10% tweak. A very modern digital unit might need access to the correct programming software, or simply be a dumb gauge and everything is done in the BCU. (That last won't be the case for an R34 though).
But as I said - no-one changes the face of the speedo then recals. You put in the whole speedo. In fact, generally you put in a whole dash.
I believe (this is a great silviaz thread where we must all interpret) that he is asking how to put a GTR cluster into the car.
But because the dials are reversed on the GTR (speedo and tacho are swapped positions) he's asking how to do it.
The answer is you buy a R34 GTT Nismo dash, which also has 320kmh on it, and will plug straight in. The longer answer is it IS possible to configure a GTR cluster to work in a GTT, so if you somehow got one of those cheaper than the Nismo GTT cluster, you could configure it to work.
Whether you have the time/skills to do it and whether it's worth the $ is another story. There's probably GTR to GTT cluster information out there. In threads like this one.
I assume also what is being asked is he doesnt want to change the whole cluster. Just the KMH dial itself and put it back together in another cluster, then recalibrate the speedo needle so it doesnt show 320kmh when the car is doing 180, and is asking how to calibrate that.
Which is doable with like a Dakota Digital speedo/signal interpreter box but jesus man just buy a cluster.
 Share
    • Yeah, pure laziness My main reason for the change is the local crappy roads, car felt great going up the Mac Pass, and then back down the long way home via Jamberoo Mountain Road after ramming a sausage roll and coffee down the gullet  But as stated, good reason to head back down for a pie or sausage roll and coffee  Some nice cars turned up at the pie shop, my fave was a mint V8 Soarer coupe, the condition of it was truly awesome  Edit: plus to adjust the dampening I need to remove the OEM front strut brace, because it covers them, and remove some of the rear boot trim, I did have my little tool kit with everything required to do it with me, but, yeah, laziness
    • Any reason you didn't, like... change it while at the Pie shop so you could compare them on the way back? (all the more reason to go for another drive I suppose)
    • After a lovely little cruise up Mac Pass into Robertson pie shop on the weekend, and all the daily driving on our crappy roads, I decided to soften up the dampers a bit I've gone from 13 clicks from full soft to 9 clicks on the front, and from 8 clicks full soft to 4 clicks on the rear Whilst the car did handle great before, on smooth roads, it was a little bit harsh on pot holes and joins in the road, but only in the rear Also, my uneducated assumption is you need more dampening in the front compared to the rear, hence the front is set a little harder by 5  Will this help the budget spec BC RS coilovers on bumpy roads, I'm hopeful.....
    • $800 Negotiable, for quick sale! Perfect to throw on your project and drive, Selling as I want to go to a different wheel combo . R32 GTST 16x6.5 wheels wrapped in Bridgestone Potenza re003 205/55r16 Tyres Almost brand new have easily over 90% tread left and retail for $215 brand new each. located: Sydney, NSW
    • Its also very clearly made to take business away from https://theskylineshed.com/ which is legitimate and even has a physical address.
