Bonnet Wont Close!
By soviet_merlin · Posted
This. So much. I tried to run mine today and it does nothing. Everything sounds normal and I can feel it sapping power so I presume the compressor is running. But it's just blowing air at ambient temperature. Regas was a few posts earlier, ~4 weeks ago. I have had it on once since then. Looking forward to see what you find out about yours. Feeling a bit like Johnny where having a modern car would be nice for a change. -
Also, it's highly unlikely to be the cause, especially if there is no milkshake under your oil cap. Goop in the cooling system is almost always rust from the block due to someone along the way not running enough coolant/rust inhibitor. If it worries you, you can try and flush everything out for a few times.
Hard plastic can be recycled, foil can't right? Can't see how this is a step foward.
So i got a 97 stagea with rb25 and it’s having issues running it starts runs for a good 10 or so seconds than shuts down used to run horrible for a few seconds till i cleaned what i believe is the IACV now it runs healthier but still shuts down previous owner ran the fuel filter backwards before realizing than putting it the right way. Cam angle sensor was replaced aswell some things are unplugged under the dash and i have no clue where they go cause previous owner did some uhhh funny wiring theres also a random plug in the engine bay where i have no clue where it’s home is lol. Vacuum is good and spark is good even when running so i’m at a loss previous owner also ran regular and i was told it needs at least premium. I guess i’m kinda lookin for some tips on other things to check i probably left out a few things i checked. Thank you all
It's not a gasket failure. AFIAK, there are no gaskets separating the two fluids. If it lets one into the other, it is broken metal.
