  • Replies 119
Posted Images
hi mate, must be your manifold..i have a 4094r on mine and mine closes no problem.get leigh or kyle to make you one up for that turbo.. if its the cam cover catching on the 32 thats a bigger problem..
Hmmm, I don't have a backing plate or cam gear cover. See if you can use tin snips to cut it off.
Yup, I had to cut out some of the bonnet reinforcement to fit over the "twin turbo" pipe as I'm running twin low mounts.. and I can't put the cam wheel front cover on at the moment as that hits too.. and my tower strut brace (cusco) would no longer clear the twin turbo pipe either - so might have to custom fab one up.. haven't tried spacers under the bonnet hinges - can you get away with 10mm though?? Would have thought it would look pretty bad fit... but maybe 5mm is worth a try - still won't help at the front though...
Rb30 sucks to fit in a GT-R in my opinion..
Goes alright though..
I don't really want to hack into my GTR ally bonnet and I'm not game enough to take the timing belt cover AND backing plate off as I'm scared I would shred my timing belt.
Can't run my strut brace at the moment but will attempt to put it back on once I go forward facing plenum and high mount turbo.. if I can't then I'll probably get a custom made brace back to the firewall.
10mm spacers is fine, that's what I have in mine and it doesn't look too bad (black car though, might look stupid on a diff coloured car).
Oh and R32 TT, saw your car on Sunday at the Autotest.. it's a fkn beast man :)
Edited by bubba
Oh and R32 TT, saw your car on Sunday at the Autotest.. it's a fkn beast man :wave:
Taking off your backing plate and timing belt cover wont shred your timing belt.
Without the backing plate and without hacking the bonnet support, I think the timing belt would be dangerously close to the bonnet.. even more so if I removed the 10mm spacers!
Oh and R32 TT, saw your car on Sunday at the Autotest.. it's a fkn beast man :P
:D Cheers mate - you'll have come a say g'day next time so I can start putting Faces to Avatars!
I would like to do a custom strut brace to the firewall as well... have you looked at this in any detail? Looks pretty busy back there... If so, have you got anyone in mind to fabricate it?
:( Cheers mate - you'll have come a say g'day next time so I can start putting Faces to Avatars!
Will do :P
Haven't looked at the firewall brace too closely yet, it's just an idea at the moment but I've seen it done in a 33 I think it was and some other cars. I'm not putting any effort into it yet until the new turbo and forward facing plenum is on as that will change things rather drastically!
I'm thinking that if my strut brace won't fit back on I'll hack it up and use the mounting rings, relocate the hinges and use some threaded rod for an adjuster in the middle. Weld a plate to the firewall with some bolted hinges so the braces can be removed easily. Really depends on where my turbo ends up :D
I honestly don't think it will be dangerously close. Do what i did when i was checking for clearances.
Remove the cover and backing pate.
Get a few pieces of blue tak, roll the pieces into a thin cigarette, about 30mm long, and stick them vertically on the highest points of the engine/belt/etc. then gently close the bonnet. If the bonnet closes properly, open it again and see how much the blue tak has squashed down. This will give you the clearances from your bonnet.
Then cam covers should still be well higher than the timing belt and the bonnet would hit these first. Just make sure you cut the bonnet support out so the bar thats removed is as long as it can be without cutting where other supports meet. this way there isnt any leftover support bar that could damage the belt. I'll post picks of mine next time I'm working on it.
sort of on the same subject, just wondering whats the best way to lower the engine to clear the bonnet, how do u go about modifying the mounts, is it a simple job or do i need to make new ones up? this is on a 2wd setup so i got abit of sump to x-member clearance to drop it down abit lower, im not keen on cutting the bonnet really. Spacers is always an option as its gonna be used for track anyway.
I did hear a rumour the other day about L28 engine mounts possibly dropping the motor..
As for timing belt clearance, I'm still not chopping my bonnet :D
Interested in photos of your bonnet though premo :)
I haven't heard that but it would make sense. An RB drops straight into a 240z and the L series engines sit low in them stock.
Pic of section cut out, the black spots are just a sticky glue that holds the frame to the bonnet skin. I used a small cut off blade with the bonnet on the car and a blanket over the engine (don't let it get hot as the paint could bubble on the other side of the bonnet) then used a knife to cut through the glue. Took less than 2min to do.
This is where that rumour of mine came from Bubba :thumbsup:
Hey boys has any one lowered the rb30/26 so the bonnet closes in a r32 gtr
meaning weather you spaced the xmember or modified the engine mounts
thanx in advance
hehe, grab the engine mounts from a LD28 powered laurelor R31 skyline station wagon, because of the deck hieght on the block the engine mounts are shorter
it was an old retired mechanic who told me what engine mounts to try. i would have never have known other wise and probably would have had to get a custom bonnet made.
  • 1 month later...
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
    • Glad it eventually came out Duncan!   I believe that might be 040. 044 is the inline pump, so has screw fittings in and out. 040 is more just drop it in fuel and the bottom is "open" (mesh) from my memory
    • well mate, while I hear your pain, turns out I don't feel it this time! Must have been a bastard of a job crammed into the boot The tank was very empty (probably pumped out, not dropped and drained because there were some fumes still) and in very good condition internally. I'm sure he never ran e85 in it I don't know what the hell Nissan's fuel tank engineers were thinking about their clipping system, this hanger was really hard to get moving but came out in the end All looks very good (as I'm starting to hopefully expect) and Matty was right it is an 023 (044) bosch which should be plenty for the injectors and turbo
    • Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8pm. Supp Regs: TBC Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid  AASA General Speed licence or (Day license is $35.00 via the AASA Website) MA Licenses are no longer accepted by AASA https://aasa.com.au/ A helmet, long sleeve clothing and it is reccomended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs Above. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Entry Link >> https://www.sauvic.com.au/entry/deca/20250208 Entry List: 1. Martin Sullivan 2. Richard Hicks 3. Warren Clark 4. Luca Stamatescu 5. Tony Buckland 6. Min Chan 7.  8.  9. 10.  11. 12.   13. 14 15.  16.  17.  18.  19. 20.  21.  22.  23.  24.  25. 26.    Reserve list 1.  2.
