Yep........................................................but only lasted 200km :)
Noticed a slight oil leak that was traced to a leak through the block. Engine is now stripped again and getting rebuilt into a new block.
Those 200km produced a grin from ear to ear, every time i drove it.
Run-in tune dyno graphs and comparisons:
  • Replies 119
Posted Images
steve, did ya get the mani custom built for the engine/turbo/car?
when i got kyle to make mine, he allowed enough room for a 45r and a 5" dump pipe :)
good luck on the cf bonnet thing, just make sure you trial fit it to ur car before you buy it!
Yep........................................................but only lasted 200km :geek:
Oh bugger! Ill be down your way for the deca masters, and then the normal deca 2 months later - will you be set for one of them? (if not both)
when i got kyle to make mine, he allowed enough room for a 45r and a 5" dump pipe :teehee:
Nah didnt, its cheap chinese sh!t - ill get a decent one for it soon enough from him, just dying to drive it again (its been like 3 years or so, yeah im actually waking up thinking about it in the middle of the night). Once its run in ill get a new manifold for it, aswel as some other bolt on parts :P
Washers under the bonnet are your friend... :happy:
Actually, on this topic, I want to lower my RB25/30 that resides in my R33 GTS-t...
What engine mounts can I go out and buy, that will directly bolt in, and lower the motor down?
Thanks All!
Appreciate your encouragement.
Hopefully car will be back on the road in the next two weeks, then i have to run it in (2 weeks), get it retuned, then install other suspension components and get it set-up for track/motorkahna. This should all be done within 2 months, so yes the car will be ready, barring any unforeseen problems/issues. At this stage i have no intension to enter DECA Masters; new engine set-up, new suspension set-up, and brakes, i will not have enough time to play around with it and get use to the new set-up. If entries are low for the Masters, i will enter but will not be "competing" to win. Either way, i will be up there to help/volunteer.
I will be at the 2nd DECA.
  • 1 month later...
Ive gone with the factory plenum changed to front facing, and am using a high mount gt35/40 replica turbo. Will i still fit the strut brace overtop or will i have to end up taking to the bonnet with my angle grinder? Id like to keep it all looking subtle so no-one will suspect a thing but if i dont have a choice il get cutting.
Mate i highly doubt the strut will fit over the plenum my strut dosent even fit over my turbo!
What the hell is a GT35/40 replica turbo? :P
Is it one of those eBay special China turbos that hand grenade after 5 dyno passes?
well today didnt actually drive the car much....paulo @ keep were trying to map the power FC for RB30...with 0piston's FC-Dataloggger, had some computer problems at the end so we decided to stop there and fix the computer...
while Gerard @ keep were doing the hood...cutting out the CF so the hood would fit.
here are the pictures
spent the whole day doing this...but still didn't fit
so we gave up and cut the whole thing out instead
Im a bit worried that the cam gears and cam covers are going to an issue for me. the turbo is fair big as well.
Is there a bonnet like the one above that is a raised flat instead of having the fake vent's?
(why is there a naked guy next to you in the reflection on the CF?)
Edited by =premo=
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
