god damit my carbon bonnet wont shut aswell!!!! The cam cover is hitting the second vent. We tried spacers but its just rasing the back of the bonnet and looks really crap aswell. Only option is to cut across half of that vent and then make up another bigger piece of mesh to cover the gap. Shoudnt look 2 bad. Will post pics once done
  • Replies 119
Posted Images
good glad i am not the only one...but hey..may be OEM hood fits better...and don't have to cut out a hole....??
The vented section of a carbon fiber bonnet is flat at the lowest point of each vent so they are possibly worse for clearance.
I have to space my strut brace up now as the cam cover is hitting it as it rev's up. Just going to try 5mm plates first to see if its enough.
Get an engine stabiliser bar thing man. Stop the engine twisting. The more the engine twists around, the less power makes it to the wheels.
The engine moves what.. an inch and a half? Two? You think this will stop 500hp getting to the wheels? :/
The engine moves what.. an inch and a half? Two? You think this will stop 500hp getting to the wheels? :rofl:
It's not stopping 500RWHP getting to the wheels...
But how much force is required for you to PUSH the engine by hand that 1.5 - 2" sideways? Measure this amount... Then realise that it's pivoting on the drives side engine mount, Measure in a straight line from the engine mount point, to the passenger side cam cover.
This is your distance. Now multiply the force in newtons you required to push your motor 1.5 - 2" sideways, and this is how much torque you're losing...
Now I know it's a fair amount of force required, and at say 1M, if you need 100newtons to push it sideways, then you're loosing 100nm of torque from the fly... See how quickly it adds up? Get the brace...
:blush: based on that theory then - if you brace it - how much force is required to move it by hand then? You won't budge it... so now you're losing ALL your torque from the flywheel?
What I am saying is the motor moves 1" to 2" yes, but then it stops - it happens in an instant - and now all your power is going through the drivetrain..
If you motor 'kept moving' (and spun around and around in the engine bay) then sure, you'd be losing power. Or am I missing something...?
Go break an engine mount, or just unbolt the passenger one. The motor will twist around a shit load more, response drops off, and so does overall power.
And if no amount of torque can shift the motor, then you won't lose any, because there is none being USED to move it no where.
And if someone sponsors me some L28 mounts, I'll change them over...
Im not exactly sure what you guys are hoping to gain by using L28 mounts,, there is no where to lower the engine.
I have plenty of sump to cross member clearance to lower my motor in the GTS-t.
The GTR I hear has a lot less room though...
Ditto, I've got may 20mm if I remember correctly.
Obviously there is a lot less room in a GTR due to using adapter plates for the sump etc.
ugh i don't care about my strut brace..i just don't want my Hood to be open like that .... it's 1) ugly, 2) ppl can do stuff to ur motor when parked 3) sh*t flies in...etc
:( based on that theory then - if you brace it - how much force is required to move it by hand then? You won't budge it... so now you're losing ALL your torque from the flywheel?
I understand what is being said and I intend to get a brace or solid mounts but the rotational force on the engine is all about inertia being transfer d from the stationary parts into the moving parts and the friction between them. The rotational force of the engine is still there even if its solid mounted only you cant see it because the force or kinetic energy is transfer d to the cars chaise. The only way the amount of kinetic energy transfer could be reduced is by using lighter moving engine parts which will also reduce the amount of inertia at top revs etc.
Please correct me if I'm wrong or loan/give me money to get my car going and I will get dyno results of before and after.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
