This is where that rumour of mine came from Bubba :P
hehe, grab the engine mounts from a LD28 powered laurelor R31 skyline station wagon, because of the deck hieght on the block the engine mounts are shorter
it was an old retired mechanic who told me what engine mounts to try. i would have never have known other wise and probably would have had to get a custom bonnet made.
Found said rumour/post again...
Try those ones?
  • Replies 119
Posted Images
  • 1 month later...
this info is probably useless to 99.99% of people but rb26/30 in a stagea and the bonnet closes with ease, without any mods at all, motor on the standard mounts and not lowered at all. Going by my measurements with some bluetack (lol) i got atleast 10mm clearance at the closest points (timing cover area).
just thought i would add this in the topic incase someone asked in future :laugh:
Edited by unique1
just thought i would add this in the topic incase someone asked in future :wub:
Well then you suck! :laugh:
I soo shouldn't have sold my 240z, there worth heaps now.
But I'm fair sure you would have even more trouble getting the bonnet to close in a zed. Also the torque might fk the 2/3rd's chassie so you'd want a killa cage or a 260z two seater.
You really don't want to put spacers under the subframe - that will raise the roll centre which won't help handling.
BTW rb25/30 in a 240z is a real bad idea. I've seen one in a 200zr and it is a terrible fit - heaps of mods required
Motor is out, again, so this is a problem i have to look forward to again pretty soon.
Short of new engine mounts, im going back to twin turbo, so the rear clearance wont be a drama. At the front the last resort is cutting the frame
hey me 2 !!
what's wrong with your RB30 this time ?
i blew the oil pump and bend the rods
You know how to shatter a man's dream :O
If an rb26 can be fitted into a 240, what makes the rb30det so difficult?
I had already factored in a very decent roll cage, brakes and suspension set-up.
WHAT NOW!?
Have you picked up that car from Bendigo? How did the other one go, the one you wanted to look at on the way back home?
Dude thats why it wasnt at DECA, it let go at Wakefield a short time ago
All good on the way back, problem i face now; where to keep two more cars
What was the aftermath from DECA for your r33?
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
