Hi I have just put some series 2 taillights onto my stagea and noticed that there was some wire which had connected up both rear lights, Now Before I connected the wire up I found that with the car in reverse the left one lite up and with the drivers lights on the right one lite up. Is that hows its supposed to be???? I ended up connecting it up as it was which means both lights now come on regardless. I also scored some wire cutters which someone left in there. Score.
https://www.sau.com.au/forums/topic/219320-reverse-and-rear-drivers-light/
There are 2 types of S2 rear lights,
normal: 2 reverse lights
cold area: left reverse and right safety red light (which only comes on from fog light switch on light stalk).
So Im guessing you bought cold area lights but dont have the cold area wiring.
some stageas have only one reverse light and one fog light( 1 white 1 red) same as some r34's as well as some euro cars, my left one is my reverse light.
    • And half of them have been converted to turbos.
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
