Hi all
Does anyone know about what kind of supercharger to go for on my v35 .Im currently looking at an eaton m90.Does anyone know of these,compatability,install info,etc.Can get in a raised hood to suit as well so clearance not an issue.Thanks.
https://www.sau.com.au/forums/topic/219366-fitting-a-supercharger-to-a-v35/
hi matt,
a few things, first have you checked out the V35-specific section of the forum? there are a few that already have supercharger kits fitted and you will get more exposure to the V35 crowd there:
http://www.skylinesaustralia.com/forums/Se...lines-f170.html
secondly, a lot of info can he had on the g35driver.com forums as fitting TT kits or supercharger kits is commonplace over there. some good info here:
http://g35driver.com/forums/forumdisplay.php?f=24
and lastly, what other mods do you have on your car?
  • 2 years later...
Hi all
hi
I recently installed a Stillen Stage 3 supercharger on my v35, i had to cut bonnet but stillen provides a nice carbon fibre moulded bonnet scoop
hmmm, there might be an hks kit specifically for v35. saw a v35 getting fitted with a blower off a 350z, wasnt a straight swap tho(be warned)
it didnt really seem worth it honestly, sure it was punchy but was a bit lacking up top, the guy with the 350z ended up putting a single 3037s kit on, big underbonnet temp issues with that, so still not a good solution. lol
those twin low mount turbo kits kits r kinda sweet, no exhaust crossover pipe and temp issues like the hks kit. but turboing it is a whole other thread.
remember those v35's r high compression like 11+:1 from memory, dont push it too hard if its stock. wont take masses of timing or boost. might have to settle for 230rwkw or so if u go supercharged.
if possible look at a m112 off a jag v8. they come with two big water to air intercoolers. i herd of a guy who fitted 1 to a 1UZ-fe.
Screw the old chargers get the new TVS chargers - they are much more efficient. http://www.eaton.com/EatonCom/ProductsServ...s/TVS/index.htm
The R1900 would be my pick for around 300rwkw @ around 6psi of boost at 6700rpm on a 3.5L.
The stock rods would go at around 250-270rwkw from what I have heard. The high rev's have lighter rods again.
Almost any good FI setup would require forged pistons and h-beams/bearings at a minimum but then you are good for a lot more than 300. I have been looking into this for my Stagea as the VQ25det's don't have aftermarket parts available and i'm not sure how far I can push it. I cant afford to put a window in the block just yet. :bunny:
  • 2 years later...
Sorry to bring up an old post but i have a V35 sedan, looking at forced induction (VQ25DET from stagea is tooooo expensive and is for AWD and my car is RWD), looking at a supercharger but im wondering if the kit for the VQ35DE would fit on the VQ25DD Neo Di or would i have to get a custom one? Anyone know a good shop tjat is willing to do it? Any help would be great
Check this link: http://www.bulletcars.com/superchargers/rotrex-supercharger-system.html and give them a call.
First hand experience with Rotrex, they are compact and virtually silent in operation.
I'd be surprised if Bullet don't have something already to suit the V35.
Fitting a supercharger would cost much more than a S/H VQ25det conversion, plus dd's are nearly 12:1 compression, it would only work if you went e85 imo.
Your gearbox will bolt straight up to a VQ25det so it is only the ecu you need to worry about.
I have the RE4RO1B four speed which is different to the box fitted to the VQ25DET. Just want a supercharger because i thought it would be an easier task than doing a VQ25DET conversion. Plus then i can say i have a superchargwd V35 sedan with a M35 stag nose
The hks won't work without modification I believe. Ive seen and installed one. The big bracket that hangs the charger and pulleys is made for a motor without variable exhaust cam. It bolts right onto the front cover there, so I'd bet that you'd have to make a new one or modify it.
The other thing you have to worry about is your direct injectors. Who knows what capacity they are, and if they will safely support the extra fuel needed for a s/c. It's not like you can drop injectors in easily, with aftermarket support. And find a ecu to work.
Have you priced a vq25det motor? I know it would be very difficult to wire in, but it should bolt right up to your gearbox, or you could use the box that comes with it without the front shaft, or even a 5spd from v35 or 350z will go in, or a manual. It's just a matter of getting everything to talk to each other. You'd get a motor for the price of one of those kits.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
