You can get away with auto ECU but ignition needs to be re-wire to bypass auto gearbox's neutral safety switch. In R32 the gearshift indicators seems to be on the dash not on the speedo cluster so you can keep your speedo, just cover the gear indicators with a plastic piece :D. Changing to manual ECU would be better cause fuel map could be different, who knows.
Dunno about gearbox but should fit, if GTS4 were available in both auto & manual.
Does anyone know for sure if there is a difference between the auto and 5spd ECU's? I am taking a RB25det from a automatic R33 GTS-t and putting it in my s14 and I am trying to figure out if there is going to be a problem using the auto ECU also. Some people have said that on the SR and KA engines there is not a difference, so I assume that the same goes for the RB series motors.
Also, has anyone on the forum completed the auto to 5spd swap? I need wiring assistance, need to know how it wires up.
Regards.
so when changing from the auto to manual what things are needed to do it.... gearbox ( are the gearbox mounts different? ), clutch pedal ( is the clutch cable or hydrolic? ) clutch master cylinder? what else?
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
