  • Replies 60
BLOWN TURBO. lol, best and worst outcome haha
oh well...forced to get a new, better, bigger turbo..*sigh* lol
cheers for the help guys. especially Mike :)
after warming up the car properly car drives fine...expect no boost. seriously got tailgated by camrys, corrollas, hyundais today lol...so embrassing as i couldnt do anything
hell yeh lol
so slowwwwwww......seriously takes like 15secs to get up to 100km/h on the freeway
btw all the symptoms of weird idling were due to the ecu thinking the turbo is intaking air when it isnt..so the air to fuel ratio of screwed up or something, hence the weird shit
yeh Ash im looking at Hks Gt-rs and hks gt2835 pro S kit atm
dont want no GCG turbo
Brendan, i doubt it'll be fixed b4 the 1st of june. if it's a 'cruise' cruise ill just drive my bro's car. but if it's for photoshoot i could still drive my car and stay in Karl and Rhy's pack haha :)
Brendan, i doubt it'll be fixed b4 the 1st of june. if it's a 'cruise' cruise ill just drive my bro's car. but if it's for photoshoot i could still drive my car and stay in Karl and Rhy's pack haha :D
it'll be a 'cruise' cruise cause i'll be there with the camry.. i can even give u a lift if u want :)
Brendan, i doubt it'll be fixed b4 the 1st of june. if it's a 'cruise' cruise ill just drive my bro's car. but if it's for photoshoot i could still drive my car and stay in Karl and Rhy's pack haha :blink:
Yay! I'm famous on SAUWA!! I'm also the laughing stock of the forum :)
At least it'll give me a chance to beat a "turbo" car :blink:
Yay! I'm famous on SAUWA!! I'm also the laughing stock of the forum :blink:
I feel you mate !! haahah .. nvm im proud of driving a NA car .. i didn't want to get a turbo in the first place so i settled for a NA car
no problems whatsoever since i got my car .. hope i didnt say that too soon !! LOL
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
