Hi Guys.
I put bigger brakes on my red stag a few month ago, brand new pads, rotors re-done .
Since then, my brakes shake very much when i brake slowly, when i brake hard, everything is okay, why.!
Edited by Stagea Denmark
https://www.sau.com.au/forums/topic/219413-r33-brake-upgrade-and-problems/
fitting 'bigger' brakes will do that, your ABS kicks in sooner. Can test by pulling the fuse on ABS, will confirm it's your abs and not a warped disc etc.
Thanks, if i remove the fuse to the ABS, will it then stop shaking, just a little test.!!
if it was your ABS, it would be getting worse under heavy braking, not better.
could be either warped rotors, badly bedded in pads or a loose wheel bearing.
This is assuming, of course, that you have had your wheels rebalanced....
There is no problems under heavy braking, only when i brake normally.
Alle wheels are rebalanced, one of my friend told me to get the front-wheels rebalanced, when the wheels is on the car, maybe it cut be the aksels.!
Are your rotors slotted?
It MAY be pad knock off. There is no chance that you have put the pads in back to front?
(It is possible to do this, especially if the left hand pads are on the right hand side of the car and vice versa)
I doubt it would be the axles, the vibration would be evident in acceleration, plus it would only be apparent when the ATESSA kicks in.
No, it is standard slots.
I didn't know it was possible to attach pads 180°, i will take a look today, thanks m8.
How can i see, that the pads is sitting in the right possision.!
sounds funny, but is the caliper bolted on tightly? does it use caliper adapters of some sort (and if so is it tight too?). And finally, is the disc centred correctly in the caliper?
Really, i have no idea, i hope everything is centred, but this is stange, i will attach some pictures of what i have mounted.
..... ummmm ok :)
did u bed the new pads in on the rotor face or just ive them a smashing, which would cause warping??? even if new.
..... ummmm ok :)
Didn't understand that, but there is (Not sure this is the right word) Cobber-grease on the pads.
What he is saying, is when you put new pads on, and this is even more important with new rotors and new pads, is you need to avoid all heavy braking when the pads are new (say, the first 500kms)
This can cause the rotors ro warp. Another thing you need to avoid, is sitting at traffic lights (or wherever) with your foot hard on the brakes as this will do the same thing.
OK, now to diagnose the problem. With the wheel off, give the brake disc a good hard shake by hand. Can you feel/hear any clunking or knocking? This would indicate something is loose - such as a wheel bearing or disc mount. If you can't hear or feel anything, you need to mount a dial indicator up and check the runout on the disc. This will tell you weather or not you have a warped rotor. If you don't get any joy from either of these 2 tests then it is time to look VERY closely at your caliper mounts.
Can anyone else add to this?
well bedding the the brakes are quite easy, 4or 5 relativelly hard stops from 80-90 kph down to 30kph to remove surface rubish off the pads which allows the disc to warm up and pads bed in, then leave brakes to cool down. process finished. also put a dial indicator on the disc surface and check runout , dont want any more than 3-4 thou . If it is the discs you will have a slight jerkiness (hesitation) when rolling with your foot slightly on the pedal. Hope this helpes
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
