oh, rev limiters kill the pumps too. if you have a "soft cut" limiter its not as bad. but a hard cut. (power fc) wont be helping. your crank is ok. it just dont like the revs and or limiter. and if you are reving it past 7k id be getting a better balancer. a r33 gtr n1 one at least :starwars:
What would you define a "soft cut" and a "hard cut" as?
  • Replies 68
Can someone tell me by looking at this list what partnumber would be needed for a r32 gtr with r34 n1 engine
probably somewhere near 400kw, and is going to be pretty much a race only car with next to no street use.
http://www.atiperformanceproducts.com/prod...s/damnissan.htm
I've gotta get one of these before i put the motor in.
this is for Ati damper.
Cheers
Just as a side note the guy who builds (or used to build) kier wilsons GTR motors at wilall works at outlaw speed shop now. He says kiers car was running the "cheaper" of the 2 ATI balancers and was fine. So thats the one i went with.
This thread is making me want to buy an ATI balancer. Can i just put one on while my motor is out or will it need to be balanced with the engine internals again?
haha you and me both..
when they are back online (down for a big update)
http://www.horsepowerparts.com/
have them for a nice price... unless you can find better price
p.s. Cheers Alex..
Edited by Angus Smart
p.s. Cheers Alex..
I have seen those guys before, cheap prices. I ended up buying one from my local supplier for 700, more expensive but I support them as when i buy other parts like lots of speed flow fittings i can bring them back if they are the wrong ones etc.
My build if very basic with N1 pump but im going to balance the bottom end and run the ati balancer, hopefully will give me no dramas.
Cheers
Just bolt it on, they are balanced from the factory, unless the machine shop used your existing balancer to rectify any other imbalances
I spoke to a bloke at Ross Tuffbond today in regards to one of their balancers. I think for many of our applications (mostly street driven sub 400kw cars), the Ross balancers are more than suitable. While the ATI ones seem like an excellent product, theyre also very expensive at over $800 in Australia. Although i have come across new ati balancers on ebay for about US$350 + $100 postage, but these were for chevy V8's etc. Im yet to get an email back from them as to whether they can get RB26 ones for the same price.
Anyway, the guy from Ross said they've developed a pulley that attaches to the harmonic balancer that drives an external oil pump used in a dry sump set up. Im thinking of heading down this path eventually in an effort to bypass the poor design of the Nissan oil pump drive. I havent researched it yet, but surely it can be done for less than the price of a Jun or Tomie oil pump (>$1500!!).
Anyone know anything about dry sump set ups???
Shaun.
ati balancer for 430-490 us for rb26 listed in the site i mentioned before.. horsepower parts
now as for drysump. i been looking at it for months, and i seen the costs of your typical normal setup
jun pump 1500
enlarged sump around 1000 ?
oil return mods 300?
now as for drysump.
the pump and the lines are the killer.
atleast 1000 for lines,
and atleast 1500 for a 4 stage pump and that only goes upwards.
tho you can source used pumps and systems from nascar teams in the states for rather cheep. and they have all the parts you need except lines...
check ebay usa for them..
i have since forgotten about drysumping for now
jun pump 1500
now as for drysump.
Yeah, i hear what youre saying. I just did 10 minutes of searching on this forum and quickly discovered that dry sump set ups are way out of my league.
There goes that idea!
Shaun.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
