  • Replies 547
Posted Images
Having a look at the first page you need a wakefield or CAMS/AASA License to be a passenger?
Also I take it we don't need the blue triangle type marker for the battery or secondary bonnet restraint?
No to all of the above :woot:
I'm fairly sure you just need to sign a passenger disclaimer.
You need either a CAMS L2S licence or a Wakefield/AASA Licence. The CAMS one costs $88 a year and is used on most tracks around the country for a number of different kind of events (particularly the L2S open days that a number of us go to quite regularly) and must be purchased before the event. You need to be a member of a CAMS affiliated club, like SAU, to get one of these too. The Wakefield licence costs $50 a year and is available on the day from the track. Please note that any passengers will also require one of these licences.
That was on the first page, Just though it meant passengers would need one of those licenses at least. If not thats great.
Actually it's just changed. Passengers do not need a license but the purpose of passengers is "driver training".
Albert - I might have some for you.
Scott - Don't worry I already put you in the second fastest group. Groups will be announced shortly.
So does that mean that passangers are allowed? I am bringing a passanger and need to let him know if he will be allowed in the car around the track.
Thanks.
Thanks.
They were always allowed. Now they just don't need a license but still need to sign a disclaimer.
I just updated this in the first post.
Gates open officially at 8am although they usually appear to be open by about 7:30.
Sign on from 8am.
Scruitineering at the scruitineering shed from 8am until 8:40.
Drivers briefing and full track walk around at 8:40am - ALL DRIVERS MUST ATTEND.
First session which will be noobs 9am.
Remember there are a lot of people to get signed on so can I suggest that noobs get there as early as possible, sign on before doing anything else then get your car ready and scruitineered. Scruitineering will stop at 8:40 for the drivers briefing and start again for the stragglers at 9.
The scruitineering will be done at the shed behind the garages. Two lines, noobs to the left, the rest to the right. Bring your helmet and what you will be wearing on the track as all this needs to pass scruitineering too.
I've got a very Newbie sounding question but I am a newbie....(and I did a search but coudln't find anything)
I need to buy a helmet for Saturday....I am assuming any helmet I buy from a motorbike shop will be good enough as long as it is a full face...also what sort of money would i expect to spend...I assume all helmets sold in Aus are approved??
Anyone in Newcastle bought one up here recently, if so who from???
Ah good question.
You can use full or open face. We reccommend full face as it's more protective.
Any motorbike shop can sell you one to your buget. You are looking from $120 - 2k if you like.
This all depends on what you want to use it for. A cheapie $120 should do you fine
Just make sure that it fits properly. When you put the helmet on make sure it's very snug. Not too tight so it's pushing your cheeks in. But wobble your head around with it on. If it moves around it's too loose.
Try this place
http://nmw.com.au/s1/index.php?option=com_...t&Itemid=63
Sign on from 8am.
shotgun going out first :D
will we progress up if we do good lap times or stay in the same group
You can also hire helmets from wakie for the day :D
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
