Hey,
Decided to sell some of my bits and pieces I have lying around that I no longer really need, and due to GTR repairs I could use a little extra cash.
All items located in Canberra, ACT.
Blitz BOV set (suited for BNR32)
Age: Unknown
Condition: 2nd hand, but have give both the pipe and BOVs a good clean. Both are functional.
Price: $200 posted
To fit: BNR32 GTR
Comments: Includes the gaskets, bolts, BOV pipe aswell as the BOVs themselves.
Exhaust Cannon, Used
Age:Unknown
Condition:Used, has been cut off from prevous car, but can still be welded again as there is sufficent pipe
Price:$50 posted
To fit:Came off a S13, but should fit any standard exhaust.
Comments: As said it came off a S13, and it appears to be a Trust exhaust end, but whether the prev owner of the car it came off just put in on??
Exhaust Cannon, New
Age:Brand new still in box(minus photo taking)
Condition:New, have used andonising spray to paint end andonised blue but can be removed with striper if not wanted.
Price:$65 posted
To Fit: Generic Autobahn brand
Comments: Generic brand from Autobahn, is new but has tip painted.
Light detector for Cefiro's automatic headlights
Age:Unknown
Condition:S/H, Clips are broken off so it cannot be mounted in factory harness.
Price:$20 posted
To fit: Cefrio or Skyline with automatic headlight setting.
Comments: Was going to convert my GTR to have auto headlights, but gave up.
Please PM me if interested.
Cheers!
Paul
https://www.sau.com.au/forums/topic/219463-r32-gtr-parts-and-other-bits/
Hey mate,
Whats the sound like on the BoVs, and do they cause any idling issues / flat spots at all?
Cheers
Andrew
Hi Andrew,
They are louder from what i remember, but as for flat spots i do not know as I only had them on a week then took them off for registration and didnt put them back on as the Stock ones will suit my needs for now.
Cheers
Still trying to sell all the parts above (including the BOVs)
PM me if you actaully want to buy them and can within 48 hours. I'm trying to sell these asap to pay for parts i need, and don't really want to wait another week.
These will fit both R32 GTR and r33 GTR, as it is a direct replacement for the stock BOVs
Thanks!
Price Drop!
BOVs: $180 posted
Exhaust cannons: $40 for either posted
Ceffy Light sensor: $10 posted
Breather filter thing: $Free if you know what it can be used for.
THANKS!
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
