hey ppl i have serched and cannot find
i have just put a s2 motor into my s1
i replaced the loom to s2 everything is s2 ecu and all
i went to start it today it turns over but wont start it has good compresion
also the starter motor make a massive squeal noise after to trys to start i brought the motor off a guy here (third motor off here) the motor seems to be fine i dint touch anything when putting it in
it tried to start but wont fire
i have checked all connections battery is charged
i live 4 hours form adelaide and thinking of trailoring it down to boostworks
can some help me
https://www.sau.com.au/forums/topic/219479-r33-s2-motor-wont-start-in-my-s1/
running stock ecu diag would provide a great help
you could check all the sensors, and check on board diag, it even tells you why the engine failed to start
put up a post in your local state chaper, asking for someone with a consult cable & software
offer some beer for a visit to come out and plug it into a laptop, will clear up a bunch of issues and sensors to ensure they are working
if you cant get access to consult - go see a work shop like you said
trying unplugging afm, see if that helps, try unplugging water temp sensor, see if that helps
goto the tutorial section, look for a post by "Cubes" he has done a wiring chart, which covers what you need
lastly if you cant find that, look at my website paulr33.skylinesaustralia.com im pretty sure the same data is on there
look under wiring diagrams on my site
can some help me
Mate try Hybrid z`s web site, It shows you every wire you need to get it going as I just did a rb25det conversion myself. It started first time I S%^T myself. I can send the file to you I has pics and all. Note 260z ignition wiring is very similar.
Zyline
Ok so first, go send that guy his oil relocation kit
Then when you have done that, check the computer. Mine did EXACTLY the same thing when I stripped my engine down. I did everything, even pulled apart the afm to check the board and cleaned that with contact cleaner, cleaned the afm, checked plugs, the comp, checked injector voltage, afm voltage blablabla. I did everything except for one of the most basic and easiest things I could have checked. Turns out somehow I got my ecu mixed with my mates when both our cars were in pieces in the garage and I had a s1 ecu, swapped back and went fine.
ok oil relocation has being send already
ok i have two ecu here but i am 100% sure the ecu im using is a s2
wat if i have wired the wires worng if someone can tell me hwat wires go to what wire from s2 loom to s1 plug that would solve my problem
Edited by teazn_r33
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
