As title says I have a set of 19" ROH drift R's to get rid off they are in good nick. There is one small mark on one of the rear rims and a mark on the inside of one of the fronts (I don't know how that got there :down: ). One of the rears is missing the R badge from the centre cap.
They have Hankook K104's on all four corners, both fronts have about 80-90% of the tread left and the rears have about 10% before they hit the wear indicators.
The rims are about 3-4 years old.
They measure 8.5 inches at the front and 9.5 at the rear. They were ordered with the offset to suit a R33 GTST, I can’t find the off set printed any where on the back of the rim. They fitted my car which has a wheel centre to guard height of 350mm and a camber kit on the front and rear, Both front and rear guards had to be rolled once the camber kits where installed.
I am located in the Hunter Valley N.S.W, feel free to PM me or post at will.
I am asking $1200.00 ono
:wub:
Ryan
https://www.sau.com.au/forums/topic/219495-19-roh-drift-rs/
  • Replies 52
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
    • I'm shocked, you've owned a Skyline since 2006 and never joined SAU before now! 😮   Welcome, it's much quieter these days than it was in 2006, but lots of very knowledgeable ones lurk around here. I actually think in outage we've forgotten more about Skylines than anyone knows about them today... 😛
    • So it could give us some info. Such as we find out what number they started at, and we know how many of those blocks came before it.
