As title says I have a set of 19" ROH drift R's to get rid off they are in good nick. There is one small mark on one of the rear rims and a mark on the inside of one of the fronts (I don't know how that got there :down: ). One of the rears is missing the R badge from the centre cap.
They have Hankook K104's on all four corners, both fronts have about 80-90% of the tread left and the rears have about 10% before they hit the wear indicators.
The rims are about 3-4 years old.
They measure 8.5 inches at the front and 9.5 at the rear. They were ordered with the offset to suit a R33 GTST, I can’t find the off set printed any where on the back of the rim. They fitted my car which has a wheel centre to guard height of 350mm and a camber kit on the front and rear, Both front and rear guards had to be rolled once the camber kits where installed.
I am located in the Hunter Valley N.S.W, feel free to PM me or post at will.
I am asking $1200.00 ono
:wub:
Ryan
https://www.sau.com.au/forums/topic/219495-19-roh-drift-rs/
  • Replies 52
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
    • I'm shocked, you've owned a Skyline since 2006 and never joined SAU before now! 😮   Welcome, it's much quieter these days than it was in 2006, but lots of very knowledgeable ones lurk around here. I actually think in outage we've forgotten more about Skylines than anyone knows about them today... 😛
    • So it could give us some info. Such as we find out what number they started at, and we know how many of those blocks came before it.
    • Everyone wants an ECU they can plug onto their engine, modified or not, and put of the box it just runs perfectly like a brand new modern engine straight off the production line. Too many people just don't understand things like the base maps are as you said, just to give a starting point, and then you need to spend time getting it right for your vehicle.   I wonder if the people wanting it are the same ones who'll just buy a chip for a "stage 2 tune" online and then wonder why their engine blew up...
    • Quite possible! And well worth checking out, as it will be more durable than paint
