Hi guys, from our experience using both engine and chassis dynos (roller) on over 20 Skylines..
Standard R32 GTST
162 kw
220 bhp
110 rwkw
145 rwhp
Standard R33 GTST
185 kw
250 bhp
125 rwkw
170 rwhp
Standard R34 GTT
206 kw
275 bhp
145 rwkw
195 rwhp
Modified R32 GTST
265 kw
355 bhp
210 rwkw
280 rwhp
Modified R33 GTST
285 kw
380 bhp
220 rwkw
295 rwhp
Modified R34 GTT
305 kw
410 bhp
240 rwkw
320 rwhp
Our old RB30DET (with a GTR box in 2wd)
345 kw
465 bhp
280 rwkw
375 rwhp
Whilst the losses aren't perfectly linear they are pretty close, a R32 GTST with manual transmission looses about 52 kw through the drive train, an R33 GTST also with manual transmission losses about 60 kw through the drive train and an R34 GTT looses about 62 kw through the drive train.
It does not seem to matter what the rear wheel power is the losses are fairly constant ie; if you double the power output at the wheels the losses don't double. They go up a little bit, but not even remotely close to linear.
This is a bit of a political subject because it is always preferable to tell people the highest power number possible. So I often here stuff like.........
"My car when standard had 185 kw at the engine and 125 rwkw, now it has 250 rwkw, so it must have 370 kw at the engine. That's 500 bhp". Well, sorry if it deflates some people, but I believe it would really be 250 + 60 = 310 kw (415 bhp).
For the clutchless people, the losses seem to be about 20 rwkw more than for manuals.
Hope that adds to the discussion
Hi guys, let me throw this one in for further thought....
It is accepted that energy can neither be gained nor lost, however it can be converted into other types of energy (that's how brakes work, turning kinetic energy into heat). Of course the Einstein E=MC2 disproves this, but I don't think there is any atomic reactions going on in my Skyline.
So if the losses are linear, where is the extra energy going? It's not "LOST", it can realisically only be converted into heat. If my gearbox and diff heated up at that sort of rate, there would be big lumps of molten aluminium all over the dyno room floor.
Ponder on that for a while
E = energy (we all know that one)
C = the speed of light (assumed to be a constant once but isn't)
M = the Mass defect (subtract the 'lost' positron/electron mass from the specific nuclear reaction from memory).
Conservation of energy applies to this equation still.
Thanks Guys it seems to be about 30% or there abouts if you are going to put a number to it . I wanted to know because after putting hks intake pod 3 inch mandrel bent exhaust hks ssbov and 11 psi boost rwkw only showed 165kw and i thought great thats only 10 % more than stock but its more like 20% more
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
