last weekend, "on a private road area" i decided to see how well these skylines do circle work, i found out, they do it quite easily.
i even started it in 2nd gear, surpised me how fast it whipped around actually.
any way the point of this post, it open wheeled for about 3 metres on the 2nd donut,
the diff seems healthy, but i wouldnt mind making it a bit tighter,
should i just go to nissan and buy some shims to tighten it up?
or is there something else i have to/should do?
cheers people.
https://www.sau.com.au/forums/topic/219530-loose-diff/
The beginning of the end.
Its a viscous diff not a great deal can be done apart from shim it which sort of works but with mine it would still single leg in a straight line; out of corners etc it would twin nicely.
If you are going to have the car making some decent power spend 1k and throw a good new mechanical in it.
https://www.sau.com.au/forums/topic/219530-loose-diff/#findComment-3872615
a grand on a new diff?? im not going to be a pro drifter mate. lol
i dont really wanna lock it, its too dangerouse....
i might just shim it tight, and see how i go, if it does do commodore style single leggers when i launch, i will definately start looking at a brand new item, prob go a mechanical two way, make it more interesting. and do it right the first time i suppsose.
https://www.sau.com.au/forums/topic/219530-loose-diff/#findComment-3872619
Nothing about being a pro drifter its just what a new diff is worth. And there's no other option apart from dodgy shimming which induces understeer and in my opinion made the car feel shit. Especially pushing in to round abouts.
Mine was tight enough to always chirp the inside wheel through corners but on hard acceleration it would still single leg.
Spend more $$ on tyres and i guess you don't have to worry about it single legging as much :)
I wouldn't go a 2 way. 1.5way for street etc.
https://www.sau.com.au/forums/topic/219530-loose-diff/#findComment-3872626
spend more money on tyres? geez, i paid 260 ea for my 18s, and i thought that was dear!
i think i will just look into a new diff, i want it to be streetable, i have driven a car with a mini-spool, and your right, it does feel like poo.
ill finish this one off first though.
come on race track! hurry up and open!!!!!!
https://www.sau.com.au/forums/topic/219530-loose-diff/#findComment-3872647
:) $260ea for your 18's eh? Try over $450ea for my car :(
Seriously though, I'd definately go for the new diff option too, like Cubes said shimming the diff does make the car feel rather pooey, especially in round-abouts; that's just my experience however. You don't need it at the moment, so I'd just put $100 or so away every pay and before too long, bam, new diff :D
https://www.sau.com.au/forums/topic/219530-loose-diff/#findComment-3872662
450??? fark! youd be scared to chirp them? every chirpie would cost you bout 15 bucks! lol
ha ha im already saving for a new turbo and fuel pump....
ill need to start selling myself on hindly street soon lol
point taken though, cheers guys
https://www.sau.com.au/forums/topic/219530-loose-diff/#findComment-3872664
i wouldnt call it a disease, but more of an addiction lol,
i wasnt going to spend a penny on it when i first got her a month or so ago......hmmmm 3 grand later, i still have more to go.
im sure everyone else on here is the same too, but hey, atleast we all have something to be proud of.
Edited by craig R33
https://www.sau.com.au/forums/topic/219530-loose-diff/#findComment-3872677
If ya down south, go poke ya head in and speak to Graham at Boss Differentials (Listed as Boss Automotive in the phonebook - Scarbourough Way Lonsdale)
He does all kinds of diff centres and diff work, and can suss it out and tell you how much ya looking at. He's also a seller for KAAZ mechanical diffs.
Service is second to none, and he's always willing to offer straight down the line advice. He has built many an old schooler diff, race cars, maintains god knows how many drifter's 31 diffs hahahaha, and tons of street cars
He'll be able to give ya an idea of the best diff centre for ya application and not let ya spend heaps of $$$ on something ya might not need
https://www.sau.com.au/forums/topic/219530-loose-diff/#findComment-3873166
I had a small bad experience with boss.. :blink:
I think he was in a rush and simply shimmed my s/h purchsed lsd.. preload was tight but there was a couple of smashed disks in there that he didn't notice. So wasted a bit of money with both the purchase and shimming of the s/h diff. :blink:
https://www.sau.com.au/forums/topic/219530-loose-diff/#findComment-3873192
yea champ, they cost alot of cash but i figure, money is money, it comes and goes whatever you spend it on, if its something you love and get enjoyment out of then its all worth it.
https://www.sau.com.au/forums/topic/219530-loose-diff/#findComment-3873968
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
