Item: nissan silvia 91 sr20det 5speed manual
Website: n/a
Item Condition: good but its running on standard ecu and injectors
*Can view the car running, Has just been on the dyno to double check.
Runs great but just needs aftermarket ecu to handle the modifications.
Compression test came back 150 all 4 cylinders
Reason for Selling: need daily vehicle
Price and Payment Conditions: quick sale $11,500 as is no rwc nor rego or swaps for Honda, preferably stock Honda civic hatch eg/ek, ae86
(cash adjustments my way) over 15k spent on putting this engine together can show receipts.
*OR*Currently getting gearbox replace also i've just purchased Apexi pfc + Hc,custom fuel rail,sard reg,550cc injectors,braided lines and fittings,z32 afm, turbosmart eboost controller can supply all this for extra $$$$$
BODYWORK:
*35mm wide fibreglass gaurds
*50mm read gaurds with petrol cap flush
*Full BN flare kit with au style grill
*Euro tail lights
*M3 style mirrors
*Vented carbon firbre bonnet painted black with awesome purple pearl.
*full respray in Tinter white with ice Blue flake
*rollin on 16" wheels
*Sunroof
INSIDE:
* Climate control/air con
* Clarion cd player/mp3 player
*6x9's and 6" speakers
* 2 gauges in dash
*all interior is in perfect condition no marks
*pwr windows all work/electric sunroof
ENGINE:
*Fully built and balanced motor/crank
*block has been bored 40thou, machined and prep'd
*ACL 40thou Forged pistons/rings/pins
*Scat H-beam forged rods with ARP rod bolts
*ACL race bearings allround
*new water pump/timimg chain/guides/pulleys/engine mounts
*ARP head studs/main studs
*New oil filter/greddy plugs/oil/fluids
*tomie rocker arm stoppers
*.8mm commetic head gasket
*head has been machined and cleaned
*Plenum
*Bosch bigger throttle body
*SS High mount manifold T3 flange
*To4 with a .63 exhaust housing
External waste gate with screamer pipe
*BOV
*600*300*100mm intercooler brand new, alloy piping
*Full 3"zausht with a cannon
*oil catch can
DRIVELINE:
*5 speed SR20 gearbox
*Never used NPC organic clutch 2800pound clamp pressure
*short shifter (disconnected still available)
*lsd Diff
*has lowered pedders springs all round
*also adjustable tie rods
*new pwr steering pump
FUEL/COMPUTER:
*550hp fuel pump
*Rising Rate fuel reg
*standard ecu/ injectors
*Custom polished fuel rail (disconnected still available)
*880cc MSD injectors (disconnected still available)
also add battery has been relocated to boot.
post-16832-1210943220_thumb.jpg post-16832-1210943297_thumb.jpg post-16832-1210943250_thumb.jpg post-16832-1210943270_thumb.jpg
Contact Details: arlie 0403 880 106
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
