Why Go From A 20 To 25
come on roy boy..
don't bring motorsport in to it.
racing prepared car compared to street car is silly.
You'll agree that a run of the mill VL flexidore is a useless chassis in comparison to an R32 gtst.
possibly good for straight line..
but turning is not it's forte.
  • Replies 66
Posted Images
Guest trikdoutvl
the reason ppls skylines handle awsome is cause jap ppl put coil overs n shit n do the suspension rite up, were as commodore nutz suspension aint that high on the list of todo things commpaired to fully hektic sterios n 20 inch mags....... lol
wat basis do u have for a vl chassic is crap commpaided to a r32.... wats to say my standard rb20 vl wouldnt be as fast around the track if i had coilovers n everything the skyline guys bolt on to there cars lol.....
i think the gtr's won in 90 roy with skafie/richards driving, i dont think the group A/walkinshaw won bathurst
skylines chassis would be a better design/stiffer. i say would be as obviously its a bit hard to do back to back testing, but theres been heaps of cases where VL's have run 11's (some faster/some slower) and you cant open the back doors for like half an hour after the run lol
as above..
the VL chassis is not stiff or re-enforced in any way.
how else do you think your LARGER car weighs 100kg less?
also, VL brakes are pretty good.. when they are bolted to a ford laser.
on the VL they are useless.
so these are some of the reasons why a regular VL would be slower on a circuit than a regular R32 GTST
VL turbo brakes are decent enough for a car of its weight. But yes the VL chassis / suspension isnt briliant. But there is plenty of aftermarket parts that will sort that out. Also, comparing a VL to an R32 is a bit rough, its more equitable to an R31. Then again the bulk of the car is dated back to the VB, so other then some small tweaks you woudl have to say the suspension wasnt all that bad, no doubt it aged quickly towards the lates 80s.
There is a VL running around doing track days in Vic with a few guys running VBs and VHs. Considering they only have about 300hp at the engine they are doing damn good times.
Point is they are not that bad you can categorically write them off
Guest trikdoutvl
caint argue with vl brakes being bad lol i call em flintstone breaks LOL..\
titan was talking about why diddnt nissan bring out rb30et's factory... 2 big capacity or something (shrugs)
ive only driven a couple of skylines n neva got to really give 1 a good driving but i giv my vl flogs n it handles good IMO but it does have pedders spring shocks panhard rod strut braces nolethane bushes.. some1 take me for a rap in there skyline with collies :blink:
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
