What was the MPH for RH9?
The first run I saw was 12.0@120...slow off the line then planted it but not a clean run. I agree - radials on first meet, would have been better.
they ran a 10.6 @ 146 to finish up. shows the car will do a 9 with a better driver and set up.
i just would have liked to have seen it run on radials. I even offered them the use of our tyres and rims.
Mark's car is definitely a machine! Would have been great to see it run a 7...
Was a good day, just a pity that it dragged out for so long before the eliminations started, and then ultimately, it got cancelled.
Oh dam was waiting for RH9 to come out :)
Wonder why Croydon hasnt prettied up Devilish...
Mark's car was awesome, did the best burnouts..I didn't see twoggle? :)
from the other thread...
News on our car...
Got diff in and running friday....put Autronic in and had a few problems getting it running. Finally got it sorted late Saturday afternoon and tuned. The ATTESSA ecu was not recieving the correct signals from the Autronic to run the 4WD. We tried bridging over a TPS signal and lost the bloody tune!! The Autronic went bonkers and took an hour to recover it. Mark retuned the car in about an hour and by midnight had it running and making good power. We again got out the wiring diagrams and found that the earlier bridge we ran was on the wrong pin...bugger. Got the TPS signal to the ATTESSA and the 4WD came alive. However the output was making the TPS ecu input unstable and we decided at 2.30am to pack it up and concentrate our efforts on Marks car. Deciding that running the car while not 100% was not worth risking the chance of damaging it...so yes with only a few hours sleep that night we rocked up and set a new Aussie GTR record.
Hey i thought it was only @137mph
But not 100%.
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
