What was the MPH for RH9?
The first run I saw was 12.0@120...slow off the line then planted it but not a clean run. I agree - radials on first meet, would have been better.
they ran a 10.6 @ 146 to finish up. shows the car will do a 9 with a better driver and set up.
i just would have liked to have seen it run on radials. I even offered them the use of our tyres and rims.
Mark's car is definitely a machine! Would have been great to see it run a 7...
Was a good day, just a pity that it dragged out for so long before the eliminations started, and then ultimately, it got cancelled.
Oh dam was waiting for RH9 to come out :)
Wonder why Croydon hasnt prettied up Devilish...
Mark's car was awesome, did the best burnouts..I didn't see twoggle? :)
from the other thread...
News on our car...
Got diff in and running friday....put Autronic in and had a few problems getting it running. Finally got it sorted late Saturday afternoon and tuned. The ATTESSA ecu was not recieving the correct signals from the Autronic to run the 4WD. We tried bridging over a TPS signal and lost the bloody tune!! The Autronic went bonkers and took an hour to recover it. Mark retuned the car in about an hour and by midnight had it running and making good power. We again got out the wiring diagrams and found that the earlier bridge we ran was on the wrong pin...bugger. Got the TPS signal to the ATTESSA and the 4WD came alive. However the output was making the TPS ecu input unstable and we decided at 2.30am to pack it up and concentrate our efforts on Marks car. Deciding that running the car while not 100% was not worth risking the chance of damaging it...so yes with only a few hours sleep that night we rocked up and set a new Aussie GTR record.
Hey i thought it was only @137mph
But not 100%.
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
