AIR/FUEL RATIO CHECK
(Valid for R34 Models ONLY. Not valid for R34 GTR)
This a great 5min test to see if your O2 sensor/Oxygen sensor is working correctly within spec.
All you will need is a paper clip or small length of wire with its end's bared.
Bend your new object into a U shape. This will become your 'Looping' tool.
You will need to pull out the Diagnostic Port located below the steering column to the right.
Step 1: Warm up the engine to normal operating temperature.
Step 2: Once your engine has been warmed. Turn engine off, turn key back to IGN.
Step 3: Hold your loop to terminals CHK and IGN on the diagnostic port for 2 seconds or more then disconnect. This now places
your car into Diagnostic Mode II.
Step 4: Start the engine and run at idle for 10 seconds or until first Engine Check Lamp Blink, then hold at 2000 rpm or higher.
Check that the the Engine Check Lamp blinks at least 5 times in 10 seconds.
Step 5: Once you have completed the test, turn the vehicle off. Turn Key to IGN and repeat step 3 to
turn off diagnostics.
It is a bit hard to count to 10 and count the Engine Check Lamp blinks at the same time so i got my mate to use my mobile phone's stop watch. I said GO and counted and he finished with STOP after the time was up. Simple!
I had an idea that my o2 sensor was shot and this test proved it by only blinking 3 & 4 times during tests.
https://www.sau.com.au/forums/topic/219569-r34-oxygen-sensor-test/
  • 4 months later...
hi man
I think my o2 sensor is stuffed. Im hoping anyway. I get an engine cut at high revs sometimes, it is one pain in the ass please if u can shead some light on the situation much appreciated
  • 1 month later...
hi man
hey mate sounds like the same problem im having, under load at about 4600RPM it cuts out and hits like a rev limiter ? anyway have a read of this
http://www.skylinesaustralia.com/forums/Mi...500-t32356.html
pretty much ruled mine down to this but im just gonna replace with spit fires :banana:
  • 7 years later...
    • We are taking pricing back to 2022! The skid pan is nearly double the size of avalon so much better for longer battle runs as seen here > https://www.youtube.com/watch?v=ANxdRf3Do2s When: Saturday 14th June 2025 Where: Winton Skid Pan (Winton Motor Raceway) Price: $145 for SAU VIC Members            $199 for non Members Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to motorsport@sauvic.com.au or print and hand in and Driver Sign In. email motorsport@sauvic.com.au To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and it is reccommended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs on the enty link. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Accommodation:  In an effort to try new things and support other country towns we thought a new location for accommodation was worth trying and Euroa was great last time plus its 30 minutes closer to Melbourne. Saturday night we will book a spot at the pub for a couple of quiet drinks.......   Book your accommodation ASAP before it sells out, there are also other options in town if you want to stay elsewhere and join us for dinner Saturday night.   https://euroacaravanpark.com.au/ Address: 73-103 Kirkland Ave, Euroa VIC 3666 Phone: (03) 5795 2160 Entry link with Full Supp Regs to read: https://www.sauvic.com.au/entry/deca/20250614 Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email motorsport@sauvic.com.au Entry List: 1.  2.  3.  4.  5.  6.  7.  8.  9.  10.  11.  12.  13.  14.  15. 16.  17.  18. 19. 20. 21. 22. 23. 24. 25. 26. Reserve List 1. 2.
    • Yeah, playing with naturally aspirated is not smart bang for your buck power wise, but then I've never been known for being smart when it comes to cars and modifications
    • I mean from V8 world there are gains to be made in intakes and such over stock items, but definitely only if you tune them. We're talking about I dunno, 10kw here and there on a 300KW v8, gains made by tuning in the 0.2 AFR that it changes so YES but also no you won't notice it other than the sound. Duct the air as mentioned 750,000 times and you will notice happier IAT's which definitely make a difference N/A. I mean my unsubstantiated guess is you'd go from 140kw with everything stock (after cams) to 145kw with everything and a tune :p
    • I decided to "spend baby spend", and "risk it for the biscuit" 2 Orders were made buying parts that I "don't really need but really really want" totalling $2.5k AUD 1: In stock items (intake plenum and throttle body) 2: The airbox thingie, with no real ETA for them getting more stock, so patience will be required
    • Any further updates on experiences with them? Anyone installed one with a getrag here as yet?
