I'm putting all these rumors to rest.....;
R33 GTST 1993, Manual
THIS CLUTCH WILL ONLY FIT AN OLDER TYPE SKYLINE WITH THE PULL TYPE CLUTCH ON YOUR SLAVE CYLINDER.
Now theres seems to a bit of confusion going on from the last posts about clutches.
Back in May my clutch went....I researched around and sourced a new clutch.
The clutch is rated at 1500kg, heavy Duty Daiken NISSAN PATROL CLUTCH.
This clutch is interchangable with my Skyline and is half the price nearly.
Different name on the box but its the same shit only different price.
The clutch was worth $300.00 from SLACKS CREEK BRAKE AND CLUTCH (See Geoff)
GAVIN WOOD installed the clutch and through out bearing & oil for $290
The feel of the clutch pedal is great. The position of the clutch pedal is great.........just like a new clutch is supposed to behave.
When I drive it hard it doesnt slip or do anything stupid.
I can drop the pedal at 3 g's and the back wheels light up pretty quick.
I highly recommend it if you have a mild to standard liner.
AND Its not 1.2 cm or 0.004mm off the floor !- Come on guys.
Any further poblems or questions u can email me; swordfish19792002 @yahoo.com.au
  • Replies 87
Very interesting! A couple of questions though - (1) When did Skylines go from the pull to push type clutch? (2) What is the standard clamping pressure of the normal factory clutch? (3) Can any Nissan dealer get these in for around that price?
JimX,
>>> I think 1995 onwards....double check with Gavin Woods, labrador QLD first.
>>> standard is 650-700kg
>>> Yes they can I think they were more expensiver of hand than Slacks Creek Brake & Clutch.
I tried Nissan on the Gold Coast and I think they were $55 more or something....Can't remember though.
Put get the part number first before u start ringin for prices.
swordfish u mean ur skyline has a push clutch dont u ? early mods have push late mods have pull my r33 gtr has pull ( the slave cil pushes to engine so it pulls the clutch away from it hence the name pull ) .
by the way all old cars had push and most late mod cars have pull
got my clutch done on tuesday;
been taking a bit of getting used to as its fully engaged about an inch of the floor;
liking it though, feels way quicker, perhaps the old clutch was slipping more than i though;
  • 4 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
