  • Replies 87
Is anyone going to come up with an actual model or part no??
I have a friend who owns a specialist 4x4 workshop and he carries at least half a dozen different clutches for the various year and models of the Patrol, and, they are not interchangeable.
  • 2 months later...
  • 2 months later...
the power limit would be like the amount of torque a patrol can throw out, plus its in a 2 ton vehicle. But I still wouldn't take it past the other daiken exedy H/D limits which are rated @ 450hp - I reckon they are a bit overrated powerwise.
Sumo
Well how come the part number for the Daiken HD for a Skyline is R5208HD...
I have spoken to both Daiken distributors and to Coventry Auto, and have recieved the following information.
"The Nissan Patrol Clutch kit will fit, it has a higher rated pressure plate than the standard Skyline pressure plate. Noting this the pressure plate is rated so as to match the torque characteristics of the Patrol engine, despite sharing similar flywheels, clutches are designed with different applications in mind."
and this
"The Skyline HD clutch has an uprated clutch plate compared to the Patrol Clutch plate. The clamping pressure is similar however the the combination of varying clutch and pressure plates are designed to take either big torque low rpm, big torque high rpm or any combination in between."
or
"We do not recommend the fitment of a Patrol Clutch to a skyline and vice cersa, they are designed for different purposes and the clutch compound is different for both kits"
Don't kill the messanger, this is the info I recieved.
just thought i'd chuck in my 2 cents, even though the two clutches would be made of different compounds the low down grip and clamp that the patrol harnesses for distribution thru 4 wheels SHOULD be a godsend for hard as fu** launches, i suspect what daiken have in mind when doing their extremely expensive r&d is how fast is the clutch going to spin with what amount of torque thru the rev range and what sort of pressure can be applied to said clutch at different points. BUT i still reckon that it is worth a try, i mean what is 5-600 bucks in the scheme of things if you are going to find cool shit that that can be cross fitted, my clutch is starting to slip too and the patrol clutch is going straight in, why not. least i know it wont fall apart on me when racing me some commode-whores! Peace.
even though the two clutches would be made of different compounds the low down grip and clamp that the patrol harnesses for distribution thru 4 wheels SHOULD be a godsend for hard as fu** launches.
You really think that Daikin chose a clutch plate material for Patrols that will withstand hard launches? How many people do you see doing high rpm launches in their Patrols?
Just because it fits, doesn't necessarily mean that it's suited to the application, is what Daikin is trying to say.
I wouldn't know what to think. There are several people here with Patrol clutches now. To you guys - How many hard launches has the clutch withstood so far?
what i was saying that is with a 2+ ton vehicle running a 4wd drivetrain, made to take the extreme pressure that mud, sand offroad etc would put on the clutch and p/plate that hard launches should be a sinch, i realise that the rpm is different with launching a line and a patrol, but it is made for a pretty heavy duty application.
this has all been extremely interesting, i feel so conflicted. i will now consider a patrol clutch. one thing no one mentioned is the torque that a 4WD has. id have to agree that if a patrol clutch can take the low end toque, it should handle high rpm dumpage from a relativly light car, for a little bit anyway.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
