I wouldn't know what to think. There are several people here with Patrol clutches now. To you guys - How many hard launches has the clutch withstood so far?
Still got the button clutch in my R33 that came with it, but I can tell you my Patrol as seen plenty of high rpm launches... :( Pulled out a stump last weekend, front hubs locked, low range, dropping clutch at about 4.5-5krpms, clutch has never had a problem. My chassis and tow points (and the tyre marks on my driveway) on the other hand....
The cheaper 3ltr Patrol that was released (I think in the late GQ model days?? can't remember) uses a RB30 (no D, T or even E!) that produces about 2 or 3kw less at the flywheel than the RB30E in the VLs. A carby and high torque@low rpm tuning will do that to you though.
I think they would be fine for a stock to mildly tuned Skyline, but I can understand too many high rpm launches could start causing glazing and other problems. The compound used would be designed for low rpm clutching/declutching whilst towing, crawling along 4x4 tracks, etc - fairly tacky for high torque. Never designed for high rpm use.
  • Replies 87
should not be a problem for high rpm dumps with gtst.
the main difference will be the mesh will happen at lower rpm in a harder fashion.
4wd clutches clamp real hard at all rpm's and is effectively just like dumping them.
Just try driving one - its designed to be either on or off.
So it is not designed to be driven while riding the clutch - thats all.
If you take off with riding the slipping clutch all the time this clutch is not for you.
If you are either going to dump the clutch or let the clutch fully engage before accelerating it is perfect.
It comes down to this - are you able to engage the clutch before accelerating or do you have to slip it to get up to 2000rpm so you can then fully engage.
This is a question I don't know the answer to as I have yet to convert mine from auto.
So someone tell me what rpm do you fully engage the clutch and do you have to let it slip to get up to that speed?
The answer is...
If you can either dump the clutch or let the clutch fully engage before bashing the accelerator on it is perfect.
If you have to let it slip a lot then stay away from 4wd clutch as they get hot real quick due to the compound being designed for low slippage. By hot I mean they smell and get spongy.
One more thing you should consider is the maximum RPM designed for the clutch. The absolute last thing you want is the clutch exceeding its max RPM and exploding, most likely taking the flywheel with it. I've seen what happens when an RB20DET loses its flywheel at 4,000RPM, lets say the car was written off. Both chassis rails cut, smashed gearbox, broken engine block, bits of the flywheel smashed both wheels, bonnet, sliced open the firewall, smashed the windscreen, missed the drivers feet by about 20cm.
In other words, ensure your PRESSURE PLATE is rated to the suitable RPM.
I'll also add another point, if you want a standard clutch to feel better and have less throw from released to full engaged, get a clutch slave cylinder with a smaller bore diameter. What this means is you need to push the pedal less to achieve full release as less fluid will be required in the slave cylinder to throw out the clutch. This also increases the clutch pedal weight so it proves you dont get anything for free in this world :D
  • 1 month later...
got my clutch done on tuesday;
been taking a bit of getting used to as its fully engaged about an inch of the floor;
liking it though, feels way quicker, perhaps the old clutch was slipping more than i though;
Shouldnt a new clutch not engage until it is nealy out? doesnt it mean the clutch is stuffed if it is engaging an inch off the floor?
  • 1 month later...
Just spoke with Gavin Woods AutoTech and they said they will do the exchange and the clutch is suitable, the reason which they do not like doing them is that the fulcum point is different and therefore takes more stuffing around trying to get it fitted, other than that he said the clutch is fine and suitable!
Sorry meant fulcrum point, now I am far from a mechanic, but I _think_ it has to do something with the pedal and how it pushes/pulls on the clutch or where it meets the pedal or something, but I really do not have a clue, just trying to remember who I spoke to (who has done one of these) tried to explain to a dumbass like me:rofl:
  • 4 months later...
  • 5 months later...
  • 1 month later...
  • 3 weeks later...
Hi guys I need the part number for the  heavy Duty Daiken NISSAN PATROL CLUTCH that you guys are using the part number listed in one of the above posts was only for a standard clutch not a HD.
cheers
same here..
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
