hey guys just a quick question about installing a pod, i've never done it before because my first car already had on when i got it.
so atm my car is in the driveway and so far it looks like this
now i know i have to attach it onto the worm clamp, but whats the thing with the wire coming out of it? and what do i do with it, do i take it out and unplug it and screw the filter straight in?
Thanks :]
Edited by morbsy
https://www.sau.com.au/forums/topic/219589-installing-pod/
hey mate if u werent too sure about it you should have asked when i sold it too you,i wud have been more then happy to explain it further and help you out.
and another tip,if you can enter the shop from the rear drive way as you wont scrap there like you did at the front one...i lernt that the hard way too ahaha.
Jack
https://www.sau.com.au/forums/topic/219589-installing-pod/#findComment-3875982
im sure he will be fine.
from the cruise wasteland thread:
i have a few times, twice in one night once, and the first thing they say is pop ya bonnet, and just start looking for defects, i got done for a loose pod filter once.
not worth the risk.
Edited by ted180
https://www.sau.com.au/forums/topic/219589-installing-pod/#findComment-3876029
hmmm i have a stock air filter and was wondering about that plug when you pull it out while the car is running it stops the engine, anway getting rid of it should i get it removed as i want a different air flow system not the gay standard one.
cheers... michael
https://www.sau.com.au/forums/topic/219589-installing-pod/#findComment-3878421
cheers... michael
'that plug' thing is your AFM (air flow meter) and all external ones like most grey imports are tempermental crap.
if your going to upgrade, a cheap replacment would be a Z32 but your going to need a remap to run it.
installing a pod is one of the easier things to do. take the AFM off the indunction pipe and attach it to the pod while its outside the car, its alot easier that way. then put it all back together. make sure your dont feck the plug by forcing it off the AFM, just wiggle it side to side and should pop off. its like a 10 minute thing to do.
Edited by Import S13
https://www.sau.com.au/forums/topic/219589-installing-pod/#findComment-3878533
i wouldnt say a z32 afm is a cheap replacement..
https://www.sau.com.au/forums/topic/219589-installing-pod/#findComment-3878749
haha just remember the plug and the "black pipe thing" known as the AFM [air flow meter] is a must you cant get rid of one but changing is ok i guess but it wont do anything good for your car unless you do the whole intake to eat more air
then you need more fuel
when you pull the plug out the car dosnt know hoe much air is being taken in thats why it dies because the ECU dosnt get the messages
other than that the pod filter question once you do it the first time you will be able to change them in 10min after that
you will get it :D
wing nuts are the best to screw it to your AFM thats all you really need to do (and put the gasket inbetween)
https://www.sau.com.au/forums/topic/219589-installing-pod/#findComment-3878893
