Microtech Lt8s
hi guys,
just wondering i have a MicroTech LT8s in my R33 GTR and its with the standard ECU and on the MicroTech site it say its for 4 cylinder only.
does anyone esle use one or is it only controlling 4 cylinders
Cheer Tom
And batch fire injection. If it was my car, unless it happened to run really well, i would pull it out and sell it. Fit an ecu far more appropriate, PFC's sell for not much more than you would get for the microtech.
I have had hours and hours of dyno tuning on a mircotech.
Cold start I had to sit on the starter for like 10seconds to get it started. (Haltech starts right away)
I would pull up at lights and the car would stall. (Haltech running idle has had zero problems.)
Haltech is so much better for GTR's (Due to 6 throttles).
All was turned by the same tuner.
your mircotech is just as good as any other computer if you use the rigth tuner
Not true, it is common knowledge that single map sensors struggle with multi throttle arrangements, hence why PFC d'jetro uses 2 sensors, and autronic uses TPS/MAP combined.
^^^^ On the money!!!!!!^^^^^^^ >_<
  • 2 months later...
sorry to drag up an old thread, but dont all map based ecu's need throttle % input?
i had a ancient map based haltech e6a & that was .
im only asking cause im considering a s/hand microtech lt12s
Edited by norwest_rumbler
 Share
