I have had hours and hours of dyno tuning on a mircotech.
Cold start I had to sit on the starter for like 10seconds to get it started. (Haltech starts right away)
I would pull up at lights and the car would stall. (Haltech running idle has had zero problems.)
Haltech is so much better for GTR's (Due to 6 throttles).
All was turned by the same tuner.
https://www.sau.com.au/forums/topic/219592-microtech-lt8s/#findComment-3878435
Not true, it is common knowledge that single map sensors struggle with multi throttle arrangements, hence why PFC d'jetro uses 2 sensors, and autronic uses TPS/MAP combined.
^^^^ On the money!!!!!!^^^^^^^ >_<
https://www.sau.com.au/forums/topic/219592-microtech-lt8s/#findComment-3878452
  • 2 months later...
sorry to drag up an old thread, but dont all map based ecu's need throttle % input?
i had a ancient map based haltech e6a & that was .
im only asking cause im considering a s/hand microtech lt12s
Edited by norwest_rumbler
https://www.sau.com.au/forums/topic/219592-microtech-lt8s/#findComment-4072727
