Guest Hawk Posted August 5, 2003 Share Posted August 5, 2003 Orighty, this is my first post here, but i need a few opinions and help on some things wrong with my 1990 Skyline TI. I did a search, but i couldn't find anything that is similar to what i'm after. Any help will be appreciated. 1. When i i turn my wheel to lock, there is a grinding noise until i set it back straight. When i bought the car, it had a silhouette steering wheel put on, so i thought it may have been a problem caused from the change, but i know nothing. 2. My windscreen fluid bottle leaks, so can i pick one up from a wreckers? 3. One of my headlights is out, how do i open up and change the bulb? Also, which bulb should i be buying? One thing to remember, is i know **** all about cars, so keep it simple. Cheers. Link to comment https://www.sau.com.au/forums/topic/21960-all-my-eggs-in-a-basket/ Share on other sites More sharing options...
sewid Posted August 5, 2003 Share Posted August 5, 2003 Firstly please dont post in colour. I can hardly read that. 1. Dunno, check the P/S belt. Is it frayed? 2. Yes you can. Lots of Jap wreckers will have these. Phone one from the yellow pages Auto Dismantlers section. 3. Open the bonnet. Look behind the headlight. Unscrew the cap over the bulb. take the bulb out. Take it with you to the nearest auto parts shop. Buy exactly the same bulb for $7 and reverse above to put it back in. Link to comment https://www.sau.com.au/forums/topic/21960-all-my-eggs-in-a-basket/#findComment-467722 Share on other sites More sharing options...
paulr33 Posted August 5, 2003 Share Posted August 5, 2003 1. check your power steering fluid - it sounds empty or leaking Link to comment https://www.sau.com.au/forums/topic/21960-all-my-eggs-in-a-basket/#findComment-469563 Share on other sites More sharing options...
Anquetil Posted August 7, 2003 Share Posted August 7, 2003 Originally posted by Hawk 3. One of my headlights is out, how do i open up and change the bulb? Also, which bulb should i be buying? http://www.skylinesaustralia.com/forums/sh...&threadid=20632 Link to comment https://www.sau.com.au/forums/topic/21960-all-my-eggs-in-a-basket/#findComment-473339 Share on other sites More sharing options...
kryz Posted August 9, 2003 Share Posted August 9, 2003 Originally posted by Hawk Orighty, this is my first post here, but i need a few opinions and help on some things wrong with my 1990 Skyline TI. I did a search, but i couldn't find anything that is similar to what i'm after. Any help will be appreciated. 1. When i i turn my wheel to lock, there is a grinding noise until i set it back straight. When i bought the car, it had a silhouette steering wheel put on, so i thought it may have been a problem caused from the change, but i know nothing. 2. My windscreen fluid bottle leaks, so can i pick one up from a wreckers? 3. One of my headlights is out, how do i open up and change the bulb? Also, which bulb should i be buying? One thing to remember, is i know **** all about cars, so keep it simple. Cheers. Go to your nearest Autorice bahn and pick up a Gregories manual for the R31. It probably won't have your Series 3 on the cover, rather a series 1. But internally they are basically the same. Link to comment https://www.sau.com.au/forums/topic/21960-all-my-eggs-in-a-basket/#findComment-477952 Share on other sites More sharing options...
zaero Posted August 21, 2003 Share Posted August 21, 2003 take it to a mechanic :0: Link to comment https://www.sau.com.au/forums/topic/21960-all-my-eggs-in-a-basket/#findComment-496241 Share on other sites More sharing options...
Dreg01 Posted August 24, 2003 Share Posted August 24, 2003 nah don't take it to a mechanic for those problems. it is a waste of money. it is good to learn how to do things yourself. You have to start somewhere. As stated above: Buy a gregories service manual. These help a LOT. 1) the noise when turning the wheel will be a power steering problem. check fluid, check for leaks. if neither of these go to: r31skylineclub.com and ask or search there. (Great site for R31's) 2) Make sure the hose at the botton hasn't come off hence the leak. Yes most wreackers will have these. What state r u in? if melb can recommend some good wreckers. 3) You get to the bulb from behind. Inside the engine bay you will see black rubber covers attached to the back of the light. pull this out then unscrew bulb and take to auto shop. any more problems just post them up, always happy to help Link to comment https://www.sau.com.au/forums/topic/21960-all-my-eggs-in-a-basket/#findComment-498798 Share on other sites More sharing options...
