Haltech R35 Gt-r Dyno & Drag Results Thread
11.1 and 126mph from a car that weighs 1740kg, and has had no mechanical changes, is nothing short of staggering.
all hail the new king of performance cars
Maybe the new ecu is a cuppla hundred kg lighter than the factory jobbie. :banana::teehee:
  • Replies 81
Posted Images
fantastic result for first time out!!
i remember being happy when my evo ran 12.4 with autronic, 3 inch turbo back exhaust, aps cold air induction, etc
boost incease and tune & 11.1 @ 124 excellent! 10's are coming very soon
So what happens when they make some more adjustments to the tuning and on a good warm day it runs a 10.9sec and they are forced to put a cage in it, will they?
Because it can't be more than a month away before it does run a 10sec pass but I can't see them wanting to strip out a perfect good R35 just to run another 10sec pass.
Its interesting that it had a higher trap speed on the third run, without the correct launch control (which as far as I understand is just the equivalent of dumping the clutch in a manual). I wonder what happened there...
very impressive especially considering that it's running street tyres. imagine what gains there would be with some semi slicks or even better some proper drag radials. :)
I think it might be a bit of a challenge fitting the 255/50/16 radials over those gi-normous brakes. :)
But running a 10 with basic mods on factory rubber and stock everything else including exhaust is phenominal. Just shows you how well this car has been designed and engineered.
Sign me up...
though I don't know if an owner would want to modify a street driven one it while its still under factory warranty if it will void the warranty... what do you guys think?
Depends on how cashed up they are?
If the purchase price was the absolute max they could afford, then I guess they wouldn't.
However, if $$$ aren't a major factor then anything goes...
Yeah definately with that mile on the third run it would have been a 10 second pass!, our first 10 pass was 10.8@ 129 mph
so the haltech gtr with a good launch is already capable of 10's. excellent result.
Edited by giant
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
